Failed to tune osc!
Page 1 of 1 [3 Posts]
terrytee
PostPosted: Tue Jun 25, 2013 5:11 am    Post subject: Failed to tune osc! Reply with quote  Mark this post and the followings unread
Fired up my a6 last night after a few weeks of none use. Osc 7 failed tried to retune and again it failed. Turned off and rebooted, hung on boot page! Again off and on booted 2nd time but still failed osc7. So hard booted holding down soft key 4. Any way in a nut shell after soft key 4 boot all was good and tuned all osc/filters with no problems. Been ok since, so my question is this, is all ok or do you guys think it may be a sign of the a6 having a issue?
sunny pedaal
Audio files: 12
PostPosted: Tue Jun 25, 2013 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
i had it once after a cold wet period of non use.
might happen sometimes, hope it doesn't return. if everything else fails , switch it of voice 7 and keep using it.
terrytee
PostPosted: Wed Jun 26, 2013 3:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks sunny, all seems to be good now but will keep a close eye on it.
