  Muied Lumens Frequencies
ACX MIDI2CV PCB layout for eurorack
Page 1 of 1 [2 Posts]
fitzgreyve
PostPosted: Wed Jul 03, 2013 4:06 am    Post subject: ACX MIDI2CV PCB layout for eurorack Reply with quote  Mark this post and the followings unread
My first post, so hopefully something useful.....
Attached are PCB layouts for a (slightly modified) version of the ACX MIDI2CV design for a 6HP eurorack panel with Doepfer power connector.
The mod. consists of replacing the four CA3140 in the original design with a quad op-amp to save space. This removes the CV offset adjust capability, but I've not noticed any serious issues with this.
There are two PCBs, one holding the PIC, DACs, Op-amp. The other holds the gate output transistors and LEDs.
The PCBs are designed for Cliff CL1384 S6/BB jack sockets (the same ones used by Doepfer?).
Other components are as on the ACX design:
http://acxsynth.com/midi2cv/midi2cvfr.htm
Built this about a week ago, fully working first time with no problems.
PCB layouts and build notes are attached (PCB print sizing is in the build notes).
I programmed the PIC16F88 using a cheap Chinese JDM (serial port) programmer using the latest version of PICPGM - no problems, worked first time.
If any questions - read the build notes first Very Happy
PCB layouts - 2 x GIF file - ready to print for press'npeel or similar
Build notes - PDF (including correct sizing for above PCB layouts)
Example panel layout (6HP).
These are provided for personal non-commercial use only.
 Filesize:  245.44 KB
 Viewed:  108 Time(s)
 Filesize:  158.11 KB
 Viewed:  99 Time(s)
 Filesize:  120.57 KB
 Viewed:  61 Time(s)
ACX MIDI2CV.fpd
 Filename:  ACX MIDI2CV.fpd
 Filesize:  1.4 KB
 Downloaded:  85 Time(s)
ACX MIDI2CV Eurorack.pdf
 Filename:  ACX MIDI2CV Eurorack.pdf
 Filesize:  1.16 MB
 Downloaded:  236 Time(s)
PostPosted: Wed Jul 03, 2013 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's good work Smile
Anybody interested in this should know there's also another Euro option:
http://cv.hexinverter.net/?page=projects&id=midi2cv-v10
There are some updates and bug fixes to the firmware behavior, but unfortunately Alain isn't going to open source the new version (4.0). So there's a trade off there beyond just cost.
