  Twyndyllyngs Live - back after 3 weeks Chez Mosc
Another ARP2600 Clone on it's way...
Page 1 of 4 [100 Posts]
Goto page: 1, 2, 3, 4 Next
Broadwave
Audio files: 6
PostPosted: Sat Jul 06, 2013 4:13 am    Post subject: Another ARP2600 Clone on it's way... Reply with quote  Mark this post and the followings unread
Just a teaser, but I'm well underway with my 2600EX clone (expanded... take a peek at the VCO's) Very Happy
I'll backtrack on the initial build later, but I'm just to excited at the moment to sit down and write up a synopsis of what I've done so far.
This is in no way competition to the TTSH project, as it's a one off that's taken 5 years to get this far!!
More to come...
Basic cabinet build with laser cut and two colour screen printed panel
 Filesize:  329.81 KB
 Viewed:  405 Time(s)
Full VCO's with sync (OSC 1 to 2 &3)
 Filesize:  330.1 KB
 Viewed:  331 Time(s)
VCO 1, 2 & 3 "Carrier" PCB's
 Filesize:  255.04 KB
 Viewed:  334 Time(s)
LFLab
PostPosted: Sat Jul 06, 2013 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice panel!
100% size or scaled down like the ttsh?
xpmtl
PostPosted: Sat Jul 06, 2013 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
wow this is a really nice beast !
congrats
Now if someone could clone the odyssey Smile
http://sdiy.xpmtl.net
Broadwave
Audio files: 6
PostPosted: Sat Jul 06, 2013 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
LFLab wrote:
Nice panel!
Just slightly down on the actual size by 12mm. I wasn't after a smaller version, but like the TTSH I could only get 45mm sliders, so careful realignment of the graphics was needed in order not to look "wrong" for the full size panel (having the extra two PWM sliders helped Smile )
@xpmtl - An Oddy clone will be on it's way, once this is done Wink
isak
PostPosted: Sat Jul 06, 2013 10:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
AMAZING WORK!!!!!
WOW Andy, you always surpris me Smile
Damn that's looking good!
2thick4uni
PostPosted: Sun Jul 07, 2013 2:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Absolutely amazing, what a beauty thumb up
How did you do the panel graphics? They look very professional indeed....
PostPosted: Sun Jul 07, 2013 8:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi. I was admiring your panel and wanted to get some ideas on how to do cutouts for sliders. I am not really a DIYer, though I have dabbled a little. I don't have tools, but I much prefer sliders to knobs. I have gotten as far as setting up a bank of sliders on circuit boards, but I have no ideas on how to make a panel with cutouts for the sliders. So, I am wondering how you do it, what tools you need, etc. Also, any tips, suggestions, links to how-to-make-slider-cutout sites would be appreciated Thanks.
Steve
diablojoy
PostPosted: Sun Jul 07, 2013 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
not sure how andy has done his panel however it looks to be professionally milled and finished.
when i do cutouts for sliders i use a 3 horsepower router and rig up some custom guides to keep it all straight . Bit size i use is 3/16 for 3mm thick material but you could probably go down to a 1/8 bit if the panel was say only 1.6mm thick. Preparation is the key here . it takes a lot of time to DIY
this sort of thing properly unless of course you have access to a cnc mill or an industrial laser cutter ?
otherwise you are down to drilling, cutting with a dremel or other small cutting wheel implement and a lot of filing , which never seems to come out all that great.
ask where the hell am I
as good an answer as any
Broadwave
Audio files: 6
PostPosted: Mon Jul 08, 2013 12:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I did all the panel graphics in Adobe Illustrator - 3 layers:
1. Laser cuts
2. Orange graphics
3. White graphics
I had the panel Laser Cut in 1.5mm Mild Steel, by Cutting Technologies in Barnsley, UK (£120.00). Then it was powder coated in satin black by Ashton Powder Coating, Manchester (£35.00), and finally a two colour screen print by MRT in Stockport (£145.00).
MDF was cut at B&Q (£28.00), Tolex, glue and case hardware came in at £53.00
So, the cabinet and panel alone came in at a total of £381.00
I have most of the components I need, just a few odd value resistors, caps and trannies to get.
The main problem I had was the size of the PCB's I could make, as my UV box can only take a maximum board size of 250 x 150mm (which is why the VCO's are on separate boards).
Busy today with the 4012 VCF... having a problem with the CV inputs at the moment - not able to scale the keyboard CV to 1v/Oct, so I'll probably have to fiddle with a few resistor values to bring it all in line Sad
Thanks for all the kind comments, much appreciated.
NoizeToyz
PostPosted: Mon Jul 08, 2013 3:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Man that looks amazing - nice one. I'll have to check out those companies for panel manufacture.
I've never used Tolex before - do you need to heat shrink it on?
Broadwave
Audio files: 6
PostPosted: Tue Jul 09, 2013 1:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I wish it was that easy Smile
Evo-Stick Contact adhesive is the best (not the spray on stuff... it's dreadful).
Luckily we've had great weather recently, so I've been able to do all the glueing outside.
Finishing the cab today, and hopefully mount the panel and fit some of the modules.
I've sorted out the problem with the VCF (ARP service manual wrong again!!!), but I'm not sure if I like the 4012... sounds a bit too aggressive, so I may put in a 4072 instead.
steffensen
PostPosted: Tue Jul 09, 2013 1:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Looking really good Andy! Amazing job you've done there.
adnauseam
PostPosted: Tue Jul 09, 2013 6:09 am    Post subject: 2600EX Reply with quote  Mark this post and the followings unread
Looks awesome! party!
The 2600 is gaining some PR due to this and the other TTSH project.
I'm really glad there's folks with patience to resurrect the classics.
Keep up the good work and can't wait to hear lots of samples!
Baloo
PostPosted: Tue Jul 09, 2013 4:49 pm    Post subject:   Reply with quote  Mark this post and the followings unread
awesome!!!!!!!
This thread is pulling to me for building a modular clone synth.
zthee
PostPosted: Wed Jul 10, 2013 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks fantastic! Great build!
AndyR1960 wrote:
I've sorted out the problem with the VCF (ARP service manual wrong again!!!).
The trimmer should be right after R145, not summing everything through it?
Broadwave
Audio files: 6
PostPosted: Wed Jul 10, 2013 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
It was the trimmer that was wrong... My service manual shows a 250 Ohm trimmer after summing - having a look around I found an amendment (for the 4072 VCF) showing an 88.7K resistor followed by a 25k trimmer, and not summed with the general CV inputs.
I've removed the 4012 and replaced it with a 4075... the inverter and level shifter are on a piece of strip board to bring it up to 4072 specs... very happy with it.
Working on the waveshapers tomorrow (the original PCB is way too big to get 3 of them in, so I need to shrink them down a bit)
Broadwave
Audio files: 6
PostPosted: Fri Jul 12, 2013 12:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Completed the cabinet and mounted the PSU Smile
Preamp, Envelope Follower, Ring Modulator, VCO's/Waveshapers and VCF all completed and working great.
Spent way too much time with the slider LEDs!! I usually use a 1.8k resistor for 15v, but the stock green LED on the slider is far too bright (don't fancy being blinded by 57 of them)... Took a leaf from my Odyssey Lumina upgrade and swapped out the R's for 27k - much better.
By a happy accident I found that the slider LEDs are removable, so I've purchased a bunch of 4x3mm blue LEDs to see what they look like.
Today, I'll be drawing up some of the remaining PCB's for the Amp/Env/Mixer.
isak
PostPosted: Fri Jul 12, 2013 1:15 am    Post subject: Reply with quote  Mark this post and the followings unread
that's cool Andy.
do you print the Arp boards?
if you do will you sell them in the future?
if yes i will definitely will want all Smile
adnauseam
PostPosted: Fri Jul 12, 2013 9:34 am    Post subject: Arp Boards Reply with quote  Mark this post and the followings unread
@isak
I believe zthee, who has recently posted in this thread, is currently in the process of ironing out the prototypes for such boards. The plan is to have panels available as well.
See this link:
http://thehumancomparator.net/
ETA September/October when I last heard
Broadwave
Audio files: 6
PostPosted: Fri Jul 12, 2013 10:14 am    Post subject: Reply with quote  Mark this post and the followings unread
@isak - Sorry, but I won't be doing much after this build... I desperately need a break Smile
I may put a PDF together with complete details and PCB foils for all the "carrier" boards and 40 series modules (along with corrections to the ARP service manual - quite a few mistakes there!)
I'm off on holiday a week tomorrow for 14 days, but I'm forging ahead hoping to get it completed before I go.
Testing the wave shapers - nice Triangle and Sine... can't get rid of the glitch, but the original VCO's have that too
 Filesize:  219.69 KB
 Viewed:  264 Time(s)
Saw and Square waves... No problems here : )
 Filesize:  224.36 KB
 Viewed:  251 Time(s)
LED's on the VCF section - much better with 27k (waiting for the blue ones)
 Filesize:  410.05 KB
 Viewed:  273 Time(s)
Just a few more boards to do... The keyboard is something I did a few years back, needs rebuilding into a decent case.
 Filesize:  255.47 KB
 Viewed:  309 Time(s)
isak
PostPosted: Fri Jul 12, 2013 1:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Andy.
That's would be great man.
Your doing more then amazing job!
Have a great vacation, you absolutely need it Wink
Thank you for everything!
adnauseam
PostPosted: Fri Jul 12, 2013 4:13 pm    Post subject: Arp 2600ex Reply with quote  Mark this post and the followings unread
So cool.
Nice work!
isak
PostPosted: Fri Jul 12, 2013 4:23 pm    Post subject: Re: Arp Boards Reply with quote  Mark this post and the followings unread
adnauseam wrote:
@isak
See this link:
Thanks for the input.
without underestimate no one (sorry if its sound like that) my heart goes with Andy and his great work.
LFLab
PostPosted: Tue Jul 16, 2013 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fantastic build!
adnauseam
PostPosted: Tue Jul 16, 2013 1:05 pm    Post subject: Re: Arp Boards Reply with quote  Mark this post and the followings unread
isak wrote:
adnauseam wrote:
@isak
See this link:
Yeah, my apologies
In NO way am I downplaying all the love and hard work you've put into your project! It looks AWESOME, Andy. I wish I could fiddle with her sliders right now.
Do you think I'll have any problem building one as my first project? Smile
I soldered lots way back in high school and I'm pretty sure I'll get any logic down pat, but it's the electronics formulas and testing I imagine will give me trouble.
Any plans for another fantastic retro build?
