  Paulo Santos Synth-ing NºX
[PCBs] Oct/Hz and trigger converter
Page 1 of 1 [18 Posts]
sonicwarrior
PostPosted: Thu Mar 14, 2013 4:26 am    Post subject: [PCBs] Oct/Hz and trigger converter
Subject description: Schematic by Magnus Danielson/ Trigger converter by Doepfer
Got the PCBs for the Oct/Hz converter from Magnus Danielson and the trigger converter (Doepfer type) today. It's 7 cm x 5 cm. I have only tested it with +/- 15V and don't know if values have to be changed for +/- 12V as I'm not an electrician.
It is meant to use an Hz/V synth with a MIDI/CV converter that doesn't support it or an external V/Oct sequencer or voltage source. The trigger converter is needed to trigger the MS series with a standard voltage trigger as they are using an inverted trigger similar to the Moog switch trigger.
Here is the interest/development thread:
http://www.muffwiggler.com/forum/topic-23490.html
I ordered a batch of 55 (0 left) and can offer them for 7 Euro each plus shipping.
You can find the documentation including a modified schematic and the board layout here:
English:
http://www.sdiy.de/en/projects/oct-hz-converter.html
German:
http://www.sdiy.de/de/projects/oct-hz-converter.html
Edit: All boards are gone!
sonicwarrior
PostPosted: Sat Mar 16, 2013 10:52 am    Post subject: Re: [PCBs] Oct/Hz and trigger converter
This is how it looks like when it's stuffed:
Note: I used different trimmers then mentioned in the documentation for P1 and P3 because I had only 50K trimmers in this footprint. P1 is only a voltage divider so that the 50K should work there, too, and P3 is a 10K, so a 50K shouldn't hurt. In the prototype I used a jumper for P3 as it didn't have an effect when I calibrated it with my MS-10. I will test this PCB with my CS-30.
P3 is meant to ease the calibration process.
sonicwarrior
PostPosted: Fri Jul 19, 2013 2:27 pm    Post subject: Re: [PCBs] Oct/Hz and trigger converter
Final spurt: Only 5 left.
Starspawn
PostPosted: Tue Jul 30, 2013 3:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Eeek, I can haz 2?
Also, it will be for my CS5 and D85 solo synth, so any tips/need to know on how you got it working with your CS30?
sonicwarrior
PostPosted: Tue Jul 30, 2013 10:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Currently 3 are physically left, but 2 of them are spoken for.
Starspawn
PostPosted: Tue Jul 30, 2013 10:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Damn, Ill take the last then and any other that might happen to be available if someone changes their minds.
Sent you email earlier.
sonicwarrior
PostPosted: Wed Jul 31, 2013 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's it. Starspawn get's the last PCB. Cool
sonicwarrior
PostPosted: Sun Mar 22, 2015 3:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Would anyone here be interested in another batch?
I would make one if 30 or more PCBs are spoken for.
Current state:
Muffwiggler x3
sequencer.de x9
= 12 total. So I would need interest in 18 more PCBs to make a new batch.
sonicwarrior
PostPosted: Thu Apr 02, 2015 7:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Current state:
Muffwiggler x7
sequencer.de x13
= 20 total.
10 to go. No interest here?
sonicwarrior
PostPosted: Fri Apr 03, 2015 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Muffwiggler + 2 = 8 to go
sonicwarrior
PostPosted: Mon Apr 06, 2015 9:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Muffwiggler + 2 = 6 to go
sonicwarrior
PostPosted: Sun May 03, 2015 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Current state:
Muffwiggler x12
sequencer.de x16
= 28 = 2 to go
sonicwarrior
PostPosted: Thu Jun 18, 2015 3:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Preparations for batch 2 have begun: I added a second hole for the tempco to support big tempcos, so batch 2 will be with Rev C:
sonicwarrior
PostPosted: Thu Aug 13, 2015 3:13 am    Post subject: Reply with quote  Mark this post and the followings unread
9 PCBs from batch 2 are left.
Won't make another batch so take them while you can.
sonicwarrior
PostPosted: Thu Aug 20, 2015 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Update: 6 PCBs from batch 2 are left.
sonicwarrior
PostPosted: Sat Oct 03, 2015 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Update: 4 PCBs from batch 2 are left.
sonicwarrior
PostPosted: Tue Oct 27, 2015 1:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Update: 2 PCBs from batch 2 are left.
sonicwarrior
PostPosted: Sun Dec 06, 2015 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Batch 2 is sold out. Cool
