crashlander42
Joined: Oct 21, 2006 Posts: 292 Location: Orlando, FL (US)
Audio files: 705
analog_backlash
Joined: Sep 04, 2012 Posts: 393 Location: Aldershot, UK
Audio files: 21
Posted: Sat Jul 27, 2013 4:02 am Post subject:
PHOBoS wrote: | nope, it could cause problems if it was the other way around (a circuit that needs 1W and you only have 400mW). but it'll work fine. |
Hi PHOBoS, your answer has driven me to madness (a very short journey...). I'm sure that I read a reply to a thread very recently which said that there was a problem replacing 400mW zeners with 1W ones, but of course, I can't find it now . I think it was along the lines of the optimum reverse currents of the two being different, affecting the "regulated" output. It may well have been (a) wrong or (b) a hallucination. Up until then, I was sure that replacing a 400mW with a 1W zener would make no difference.
If anyone remembers this (possibly imaginary) thread, please let me know!
Gary |
Audio files: 705
analog_backlash
Audio files: 21
Posted: Sat Jul 27, 2013 8:13 am Post subject:
Just worked it out - I saw it on the muffwiggler forum:
http://www.muffwiggler.com/forum/topic-86024.html&highlight=zener
I don't know if this link will work, because I always have problems with these links. Anyway, the quote from daverj says:
"There is a slight difference when substituting a 1W Zener in place of a 400mw Zener. The Zener voltage for each is defined at a specific current. Besides the maximum power that the part can handle (the wattage), the test current used to find the Zener voltage is typically higher on the 1W Zener.
What that means is that at a lower current the higher wattage Zener will typically have a lower than rated Zener voltage.
For example, the 1N4734A (1W) has a Zener voltage of 5.6 volts when 45ma is flowing through it. While the 1N5232B (0.5W) has a zener voltage of 5.6 volts when 20ma is flowing through it. Lower the current on either one and the actual voltage across it will be a bit lower."
I wasn't imagining it after all . I don't think that it will make a huge amount of difference by the sound of it.
Gary |
Audio files: 705
Audio files: 278
Posted: Sat Jul 27, 2013 9:05 am Post subject:
analog_backlash wrote: | I don't know if this link will work |
Prolly not ... well .. for members only:
Quote: | IMPORTANT NOTICE - In order to conserve server resources for active members, the forum permissions have been changed so that only logged-in users may now browse the site. At any given time around half our traffic has been coming from "guest" users, so I'm hoping this makes a significant difference in terms of server performance. |
Too bad - I liked browsing there at times _________________ Jan
Posted: Sat Jul 27, 2013 11:14 am Post subject:
Jan, the limits haven't solved the problem, so hopefully eventually when they find the REAL problem they'll open it back up for guests. |
crashlander42
Posted: Sun Jul 28, 2013 12:00 pm Post subject:
Gary |
That's what i was worried about. I've going to use them and cross my fingers. _________________ When they plug me in the lights go down in Hong Kong.
My DIY stuff Flickr |
analog_backlash
Audio files: 21
Posted: Tue Aug 06, 2013 4:12 pm Post subject:
Blue Hell wrote: | analog_backlash wrote: | I don't know if this link will work |
Too bad - I liked browsing there at times |
Just in case you haven't read it Jan, muffwigglers now says "We will be restoring guest browsing again in the next day or two as well." Hopefully, this will be the case. I mainly registered with them so that I could look at the links other people had posted here. I much prefer e-m (what a creep I am ).
Gary |
Audio files: 278
Posted: Tue Aug 06, 2013 4:18 pm Post subject:
Ah cool.
creeps? where?
Anyway, hope they solved the problems then, and thank you for telling me. _________________ Jan
Posted: Tue Aug 06, 2013 6:41 pm Post subject:
That message has been up more than a couple of days, so I suspect Muff is running behind on that promise, but things ARE much better over there most of the time. There are occasionally slowdowns, but it seems likely that they correlate to the maintenance activities that Muff has added to the server, and they don't seem to be very long lived. |
analog_backlash
Audio files: 21
Posted: Thu Sep 05, 2013 3:33 pm Post subject:
Just for info, looks like muffwiggler's finally open to the general public again .
Gary |
Audio files: 278
Posted: Thu Sep 05, 2013 3:56 pm Post subject:
Looks like :-) _________________ Jan
