Midi to CV inside midi keyboards
Page 1 of 1 [5 Posts]
isak
PostPosted: Sun Jul 28, 2013 3:46 am    Post subject: Midi to CV inside midi keyboards Reply with quote  Mark this post and the followings unread
Hi guys.
I have this idea of connecting the next midi to cv inside my midi keyboards and get the power from the USB of the midi keyboards.
http://www.acxsynth.com/midi2cvlite/midi2cvlitefr.htm
Will I get troubles powering the midi keyboards and the midi to cv using the USB as my power source for both?
Isak.
JovianPyx
Audio files: 224
PostPosted: Sun Jul 28, 2013 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
USB supplies power at 5 volts and 500 mA. If the two together draws more than 500 mA, there will be problems. So you need to know two things: Current needed by the keyboard and the current needed by the MIDI to CV. Add that together. If more than 500 mA, problems are likely.
Time flies like a banana.
corruptio optimi pessima
isak
PostPosted: Sun Jul 28, 2013 12:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for replying.
Naturally, deferent midi keyboards takes deferent currents.
I have few midi keyboards.
The funny thing is my most smallest midi keyboard I have takes the highr current.
It's 500mA.
I guess no midi to cv in my small keyboards.
bubzy
Audio files: 64
PostPosted: Mon Jul 29, 2013 2:05 am    Post subject: Reply with quote  Mark this post and the followings unread
and, of course, unless whatever you are controlling with the voltage runs off +5v CV in then you are going to have to build a separate scaler.
_Richard_ Smile
isak
PostPosted: Mon Jul 29, 2013 2:14 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Smile
