power supply layout
Page 1 of 1 [3 Posts]
feggster
PostPosted: Mon Jul 29, 2013 6:58 am    Post subject: power supply layout Reply with quote  Mark this post and the followings unread
I ran out of copper clad board ! so had a go at laying out the adjustable power supply on stripboard, its untested and unverified so not advised to use..
http://www.musicfromouterspace.com/analogsynth_new/POWERSUPPLY2009/PSUschematic_schem.pdf
could someone have a look and see how far off I am. Please
 Filesize:  111.25 KB
 Viewed:  104 Time(s)
Audio files: 550
PostPosted: Mon Jul 29, 2013 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
you need to move the bridge just above the 'adj' pin of Q2 up one trace
D2 should go between 'out' and 'adj' (Q2)
C9 should be connected between 'adj' and GND
and -V out should be taken one trace higher.
the rest looks fine I think Cool
o and you might have to cool those regulators depending on the current you'll be needing (and the input voltage).
feggster
PostPosted: Mon Jul 29, 2013 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the eyes PHOBoS, do not know how I left those mistakes in Shocked
I might populate this tommorow..if the copper clad board i ordered today doesn't turn up!
