5V gate to 10V or more
isak
PostPosted: Tue Jul 30, 2013 6:32 am    Post subject: 5V gate to 10V or more Reply with quote  Mark this post and the followings unread
Hi guys.
i want to boost the 5V gate of my midi to CV to 10V/12V/15V gate
i found this...
http://www.musicfromouterspace.com/analogsynth_new/CVANDGATEDIST/pdf/schematic_pg1_schem.pdf
my question is...
i see in the scheme that TL074 is only for buffering.
can i use only the first part of the schceme without using the TL074 buffers?
i mean output directly from pin 14.
will this increase the 5V gate to 10V or more?
in addition i see that after the buffer of the TL074 the scheme shows a diode, should i use one from pin 14 and then to output?
i'll be using TL071 for this project.
Isak
EDIT:
i attached a pic i edited from the scheme, this is what i meant, will it do the job of boosting the 5V gate?
 Filesize:  19.81 KB
 Viewed:  1084 Time(s)
