A6 - Sequencer Syncing and Patch Selection from DAW issues
Page 1 of 1 [4 Posts]
Chauncey_Gardner
PostPosted: Mon Jul 29, 2013 11:57 am    Post subject: A6 - Sequencer Syncing and Patch Selection from DAW issues Reply with quote  Mark this post and the followings unread
Hi
I just re-bought an A6 I had sold some years back (huge mistake selling it).
I have a few issues I cannot figure out though. I thought I remembered how to do it but I guess not
First, I want to sync all of the sequenced and arpeggiated stuff to MIDI clock. It is pretty obvious how to do that if you want things playing at like 240 bpm or whatever the clock rate is.
I cannot find how to divide the incoming clock rate. I did go back to deciding to trigger the sequencer clock from LFO3, which should be able to sync to external midi and has a division capability. That route did not let me change the tempos at all. I am convinced I am doing something bad wrong. Does the DAW (Sonar) need to transmit midi clock? It sounds like the sequencer is synced but at a speed that is way higher than I want.
Secondly, I have Sonar set up to change banks (controller 0 I think) but it will not let me select the user bank - only the presets. Any way around that?
Thanks in advance for your help!
Jay-A6
PostPosted: Fri Aug 16, 2013 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is that MSB/LSB?
|EIther way Id be looking for the answer my self!
Jay-A6
PostPosted: Sun Jan 12, 2014 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
FFFFFFFFFFFFFFFFFFFFFFFFFFUK
No one knows this! ?
I have this half way working but something is still wrong.
Angroc
PostPosted: Tue Jan 28, 2014 8:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Grabbed this from the tips and tricks doc. Might this be it?
4.13 LFO SYNC: THE TIXPRD PARAMETER (1/2 note sync, ¼ note sync, etc.)
TIXPRD is a one of the parameters in the SYNC menu. Normally, you hit soft button 3 to enter the LFO sync menu, and you hit LOCAL, CLOCK, AND MIDI to sync to either the A6 master clock (CLOCK) or the MIDI clock (MIDI). TIXPRD allows you to adjust the sync below the standard 24-ticks-per-beat.
This means that you can adjust your LFO speed to ½ MIDI note values, ¼ MIDI note values, etc. easy. Simply divide 24 ticks up. For instance, setting TIXPRD to 12 will sync to double speed (to every MIDI ½ note). Setting TIXPRD to 48 will sync the clock to half speed (every second MIDI note).
