More Power Supply questions
Page 1 of 1 [7 Posts]
PostPosted: Sat Aug 17, 2013 8:20 pm    Post subject: More Power Supply questions
Subject description: Power One overload protection wiring?
I just got a new (to me, but very nice and clean) Power One supply at a very good price (thank you ebay!)
I noted that "out+" and "out-" are already wired to a little 1.5" square board that has something on it about OVP Adjust (and a trimmer). I haven't seen this on my previous purchases. So that leads me to a few questions:
1) I don't know what I might need to do to trim that (or if I do)
2) do I use "out+" and "out-" for my power distribution, or do I use S+ and S- (which aren't connected to anything else obvious).
Thanks....
JeanFé
PostPosted: Mon Aug 19, 2013 7:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Emelgil,
1) trim them until you get a nice -/+15V or -/+12V off PSU
2) these are sense terminals, to compensate voltage drops. you need to connect -S to -Out, +S to +Out, and +S/-S to COM (ground)
Check also if jumpers on the transformer are right Wink
PostPosted: Mon Aug 19, 2013 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
JeanFé wrote:
Hi Emelgil,
I'm confused though; there are trimmers on the main board for this, I've used them on all the other power supplies. I'm talking about a single trimmer on this secondary small board that appears to have something to do with overload protection.
I have checked the transformer jumpers, they match the table on the front for what I want to do. And the commons are all connected together as expected.
JeanFé
PostPosted: Mon Aug 19, 2013 9:19 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, mine must be older than yours then (HAA15-0.8 / Sept. 1988), as I don't have any additional board.
A pic would probably help..
PostPosted: Mon Aug 19, 2013 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Yah, I probably should have done that.
Here we go:
 Filesize:  1.09 MB
 Viewed:  55 Time(s)
 Filesize:  578.06 KB
 Viewed:  52 Time(s)
analog_backlash
Audio files: 21
PostPosted: Mon Aug 19, 2013 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi elmegil.
I don't know if this will help at all, but I've looked at datasheets for Power One's PSUs e.g.:
http://www.westfloridacomponents.com/mm5/graphics/ds6/SeriesIntl-PowerOne.pdf
The overvoltage protection board (OVP12) seems almost identical to the one in your photograph and seems to be an optional add-on circuit, so I guess that you don't have to use it if you don't want to. As for adjusting it, I'm not sure that the datasheet helps much.
Gary
PostPosted: Mon Aug 19, 2013 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yah, that's definitely it.
Bah on no good docs online (at least in the searching I've done so far)
I did find this: http://us.tdk-lambda.com/ftp/AppNotes/HSeriesANmanual.pdf
Edit: And here we go: http://us.tdk-lambda.com/ftp/Manuals/LLS6_8_9000Inst.pdf It's for a Lambda supply, but something I saw indicated that the OVP was a Lambda part.
Summary version:
set OVP to max (full clockwise)
set voltage output to desired trip point (V + 15%)
turn OVP pot ccw until it trips
disconnect from input power
set voltage output down a bit
turn it back on
adjust the voltage to the nominal value.
I'm assuming since it spans V+ to V- what I'd want it set to is (V+ - V-) * 1.15, or 34.5V
