fantozzi
fantozzi
Posted: Wed Aug 21, 2013 6:10 am Post subject:
pics |
pics
Description: |
Filesize: |
40.87 KB |
Viewed: |
2014 Time(s) |
Description: |
Filesize: |
29.44 KB |
Viewed: |
2014 Time(s) |
Description: |
Filesize: |
29.71 KB |
Viewed: |
2014 Time(s) |
Audio files: 705
Posted: Wed Aug 21, 2013 6:22 am Post subject:
nice! I like the different options it has, like using the gate out to clock the (CV) sequencer, a simple way to create a swinging sequence.
I would add a buffer to the CV out though (opamp as voltage follower). And maybe an extra option to set it to a different amount of steps,
you can get nice variations if you would set the gate sequencer to 7 steps. Of course you can always keep adding things.
edit: something I just noticed, you're probably gonna use more then one jumper at a time (for the gate output). If so you should add
some diodes in series with the jumpers else you'll be shorting the outputs of IC3. _________________ "My perf, it's full of holes!"
JingleJoe
Joined: Nov 10, 2011 Posts: 878 Location: Lancashire, England
Posted: Wed Aug 21, 2013 1:20 pm Post subject:
I have the core concept of this thing sitting on my work bench right now. I just needed a CV source to test things so I whipped up a little sequencer, it can go into audio range aswell so I can generate some stepped waveforms and observe things on a scope more easily.
So unfortunately not a new concept but a very useful one for a quick and easy CV source. _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
Green Dungeon Alchemist Laboratories |
fantozzi
Posted: Thu Aug 22, 2013 5:18 am Post subject:
Thx PHOBoS,
i added a Workaround in the first Post,
the jumpers must are Diodes now.
I have drawed 2 new Versions.
One implement a step lenght option on step 5,6 and 7 and the manual Reset. The other has one more Option on the CV-Reset.
The step lenght option i have also in the prototype now.
cheers
gabbagabi c/o fantozzi
Description: |
Filesize: |
36.49 KB |
Viewed: |
98 Time(s) |
Description: |
Filesize: |
22.01 KB |
Viewed: |
106 Time(s) |
