Dirty LiL Sequenzer
Page 1 of 1 [5 Posts]
fantozzi
PostPosted: Wed Aug 21, 2013 6:00 am    Post subject: Dirty LiL Sequenzer
Subject description: kind of new concept?
Dirty LiL Sequenzer,
Prototype finished.
It is a 8 Step sequenzer (4017), instead of 8 Pots i use only 4.
Instead of Switches i use jumper.
With every Gate u choose, the CV Counter advances.
It is a simple design but, by changing the source of clock and reset and by using less or more than 4 gatesteps, it has some features.
The design is easy adaptable to different amounts of steps'n'pots.
Below the Schemo and some pics of the Prototype.
In the prototype i have added two momentary-switches for manual gate and reset, and dont have the RangePot.
-EDIT-
Jumpers must are Diodes, thx PHOBoS.
Better Schemo attatched.
-EDIT END-
cheers
gabbagabi c/o fantozzi
 Filesize:  29.01 KB
 Viewed:  60 Time(s)
fantozzi
PostPosted: Wed Aug 21, 2013 6:10 am    Post subject: pics Reply with quote  Mark this post and the followings unread
pics
 Filesize:  40.87 KB
 Viewed:  1433 Time(s)
 Filesize:  29.44 KB
 Filesize:  29.71 KB
Audio files: 545
PostPosted: Wed Aug 21, 2013 6:22 am    Post subject: Reply with quote  Mark this post and the followings unread
nice! Very Happy I like the different options it has, like using the gate out to clock the (CV) sequencer, a simple way to create a swinging sequence.
I would add a buffer to the CV out though (opamp as voltage follower). And maybe an extra option to set it to a different amount of steps,
you can get nice variations if you would set the gate sequencer to 7 steps. Of course you can always keep adding things.
edit: something I just noticed, you're probably gonna use more then one jumper at a time (for the gate output). If so you should add
some diodes in series with the jumpers else you'll be shorting the outputs of IC3.
SoundCloud BandCamp AcidTrasH Stickney Synthyards
JingleJoe
PostPosted: Wed Aug 21, 2013 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have the core concept of this thing sitting on my work bench right now. I just needed a CV source to test things so I whipped up a little sequencer, it can go into audio range aswell so I can generate some stepped waveforms and observe things on a scope more easily.
So unfortunately not a new concept but a very useful one for a quick and easy CV source.
fantozzi
PostPosted: Thu Aug 22, 2013 5:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Thx PHOBoS,
i added a Workaround in the first Post,
the jumpers must are Diodes now.
I have drawed 2 new Versions.
One implement a step lenght option on step 5,6 and 7 and the manual Reset. The other has one more Option on the CV-Reset.
The step lenght option i have also in the prototype now.
cheers
 Filesize:  36.49 KB
 Viewed:  49 Time(s)
 Filesize:  22.01 KB
 Viewed:  53 Time(s)
