furio
Posted: Sun Aug 25, 2013 1:21 pm Post subject:
Is the switching lug used for something else? If not, you could add a ground connection to it, was my point. Then you don't have to worry about the position of the attenuator, input will be always grounded unless there's a jack inserted. |
furio
Posted: Sun Aug 25, 2013 8:16 pm Post subject:
elmegil wrote: | Is the switching lug used for something else? If not, you could add a ground connection to it, was my point. Then you don't have to worry about the position of the attenuator, input will be always grounded unless there's a jack inserted. |
OK, thanks for the advice! I was inspired by the Andy's PCB and he had not used the switch.
P.S. Gnd is on the vertical and the switch is not used.
Description: |
Filesize: |
102.42 KB |
Viewed: |
32394 Time(s) |
Description: |
Filesize: |
35.19 KB |
Viewed: |
724 Time(s) |
isak
Posted: Fri Sep 06, 2013 4:36 am Post subject:
furio wrote: | My new HiFi version sounds amazing. |
ive never saw pink resistors before, cool.
are they 5%? _________________ http://www.myspace.com/mgmtrance |
furio
Posted: Fri Sep 06, 2013 9:08 am Post subject:
isak wrote: | furio wrote: | My new HiFi version sounds amazing. |
are they 5%? |
no, the pink are 2% carbon film by Takman... many of the values are more accurate than most 1% metal film. |
isak
Posted: Fri Sep 06, 2013 11:52 am Post subject:
Thanks for the info.
I got one question about this vco..
I have a small issue with the scale.
When turning the vco on and play C2 it plays C2 but with +20 cents, after 5 min or so it stable on center of C2, any ideas why its like that?
The Tempco is between the 3906 and 3904 with thermal Gris, really don't know why it's acting like that.
Do I really need to wait for the vco to worm up?
Strange, don't you think?
Cheers. _________________ http://www.myspace.com/mgmtrance |
furio
isak
Posted: Fri Sep 06, 2013 7:18 pm Post subject:
Thanks.
I used 1% resistors in the vco, the caps are all wima polypropylene.
It's sound amazing but I have this irritating drift when turning it on.
I guess I have to live with that..haa
45 min? Its damn long to wait for play, LOL.
wander what kind of resistors ARP used in the ody synth. _________________ http://www.myspace.com/mgmtrance |
paulstone
Posted: Wed Sep 18, 2013 8:59 am Post subject:
Hello guys
for this VCO it is possible to use the array CA3046 instead of the CA3086 ?
the CA3046 i have to much in home , for the CA3086 is difficult to find
thx !
Paolo |
isak
paulstone
Posted: Wed Sep 18, 2013 10:15 am Post subject:
isak wrote: | Hello
Yes, you can use them, they work great. |
thanks Isak for your fast info |
noiselector
Posted: Wed Feb 12, 2014 9:51 am Post subject:
I have built a two of them but one gets a lower pitch than the other one even adjusting the freq trimmer to maximum.
Any help? |
robboten
Joined: Nov 26, 2009 Posts: 36 Location: stockholm, sweden
Posted: Sat Feb 15, 2014 4:34 am Post subject:
Hi. Just built this lovely thing. Love the PCB-layout btw! It's beautiful! I use 12V euro and just read about the PW resistor mod and will use that. Otherwise everything as in first post, except 5906 instead of 5910 and 5457 instead of 5459.
Another thing thats bothering me a bit is the range of the Coarse Freq pot. Without V/O CV (keyboard) I get about 15Hz-70Hz by turning the pot. With Keyboard plugged - C2 as lowest and upwards so far as my keyboard goes. If I tune it up to have higher Hz without keyboard, the lowest note is too high with the keyboard. Is there a way to increase the Coarse freq pot range or is there anything fishy about this? Also - the coarse freq pot is in reverse. If I turn it up the freq goes down... Otherwise everything else is great. Any ideas? |
furio
Posted: Tue Apr 29, 2014 2:43 am Post subject:
Odyssey's Ring Modulator: 22K, 22K, 100n, 150K, 150K, 5K6, 2N3904, 1N4148, 330K, 1N4148, 150K (back), 150K.
Description: |
Filesize: |
507.36 KB |
Viewed: |
576 Time(s) |
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Sat May 31, 2014 1:23 am Post subject:
Isn't the 270K resistor which is connected to VCO1 Freq trimmer suposed to connect to something?
mono-poly
Posted: Sat Jun 21, 2014 12:06 pm Post subject:
anyone??? |
robboten
Posted: Tue Jun 24, 2014 2:47 am Post subject:
Found my error. It was a small gap in my home made PCB, as usual. The negative Voltage didn't reach the pots. So simple, but yet so common. Now I'll just tune it again. |
bamboombaps
Posted: Tue Aug 30, 2016 3:42 pm Post subject:
may the lord forgive me for bringing this necro thread back to life, but i could really use on the of the panels if anyone has one? |
supercolio
Posted: Mon Mar 20, 2017 1:06 pm Post subject:
Hi! I wonder if anyone reads this thread, but can someone measure voltages from working unit, I built one and as of yet it doesn't oscillate, or make any noises as a matter of fact. I have ordered new chips so I'll try those too... Thanks! |
JP8
Joined: Mar 25, 2019 Posts: 1 Location: Amsterdam (NL)
Cathmart
Posted: Tue Apr 09, 2019 9:55 pm Post subject:
Arp Odyessy - PCB Pusherman 2019 |
Hi...any help with the parts layout for the Current ARP Odyessy VCO sold on Pusherman.....it is SIGNIFICANTLY different to the pcb info here.
thanks
sorry attachment went twice....
Description: |
Filesize: |
1.11 MB |
Viewed: |
287 Time(s) |
Description: |
Filesize: |
1.11 MB |
Viewed: |
302 Time(s) |
icnagy
Posted: Wed Apr 10, 2019 3:18 am Post subject:
Re: Arp Odyessy - PCB Pusherman 2019 |
Hi Cathmart,
I think you're looking for this repo: https://github.com/PhilicityK/ARP_Odyssey_VCO
Cathmart wrote: | Hi...any help with the parts layout for the Current ARP Odyessy VCO sold on Pusherman.....it is SIGNIFICANTLY different to the pcb info here.
thanks
