loong term minisyth construction
Page 1 of 1 [3 Posts]
kevhurley
PostPosted: Mon Aug 26, 2013 7:40 am    Post subject:  loong term minisyth construction
Subject description: heat sink?
well I,m very gradually assembling my mini synth and as I have not worked a lot recently with circuit board assembly I wonder If you need to use a clip on heat sink when soldering all the diodes and transistors. I have sockets for the ICs. Seems to me years ago that was always the prudent thing to do.Thanx for any advice.
PostPosted: Mon Aug 26, 2013 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I haven't used heat sinks except when I had an older, non-temp controlled iron, and I haven't seen any problems....
kevhurley
PostPosted: Tue Aug 27, 2013 5:32 am    Post subject: Reply with quote  Mark this post and the followings unread
my iron is a simple 15 watter.
