<on air> Various Artists Live streaming concert in memory of Antimon
 Forum index » DIY Hardware and Software » The Repair Shop
Help with a partially working SH-09 ADSR
GNSDG
PostPosted: Tue Aug 27, 2013 6:25 am    Post subject: Help with a partially working SH-09 ADSR Reply with quote  Mark this post and the followings unread
Hey all--first post, here! Not sure I'm putting this in the correct spot, but the short is that my SH-09's sustain slider is not functioning. It had been spotty for a long time before I began a suite of mods to the synth to give me modular-like access to the SH-09's guts, and actually it was functioning perfectly for a while during that process. Now, however, it's not working at all. It's as if the slider is at full sustain regardless of it's position.
Given the symptom, I checked that the connection to ground at the bottom of the pot is solid. It is. Then I checked that the actual resistance between wiper and end was changing correctly, and it does seem to be. So, now the trail runs a bit cold for me.
Here's a link to the service manual, which has the full schematic:
http://manuals.fdiskc.com/flat/Roland%20SH09%20Service%20Manual.pdf
What I'm wondering now is if it's possible I accidentally shorted drain to gate or something for one of the transistors Q26-Q28 somewhere along the line. This doesn't seem likely to me because the problem had manifest itself years before I started the mods, but who knows?
So, of course any insight you guys have is very, very much appreciated. Specifically, I'm wondering if you can tell me how I might test for problems in the functioning of those transistors. (I wouldn't mind just replacing them, but of course C1740s and A826s are not in plentiful supply these days, and my SS chops are weak I'd be hesitant to pick replacements.)
Thanks, gentleman.
