  Muied Lumens Frequencies
DIY Spring Reverb Module
Page 1 of 1 [5 Posts]
Dogenigt
PostPosted: Tue Aug 20, 2013 5:19 pm    Post subject: DIY Spring Reverb Module Reply with quote  Mark this post and the followings unread
I just finished building this Spring Reverb Module, which is basically just a spring reverb tank with an amplifier circuit for mixing dry/wet and "decay time".
Check this link for video and guide/schematic.
http://www.dogenigt.com/2013/08/spring-reverb-module.html
www.dogenigt.com
Everything should be made as simple as possible, but no simpler. - Albert Einstein
the19thbear
PostPosted: Wed Aug 21, 2013 2:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
FEDT! godt arbejde:)
umschmitt
PostPosted: Fri Aug 23, 2013 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hej! Battery operated spring reverb… Looks (and sounds) cool. Nevertheless, I can't help scratching my head when looking at the symbolic drawing on your site. You could use just the half of them op-amps (yes it'd be 1 1/2), or am I missing something? Shouldn't the mixing stage be biased also?
::U::N::S::C::H::N::E::L::L::
Dogenigt
PostPosted: Thu Aug 29, 2013 11:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey thanks for feedback! Yeah, actually I now see that I forgot to bias the mixer! I don't notice any loss in signal quality - is it only producing signal in one polarity then? I will have to fix that! 2 resistors of same ohm from ground and + like the others? And yes, I had some bleed-through with the op-amps for some reason so I chose to use seperate ICs.
www.dogenigt.com
umschmitt
PostPosted: Fri Aug 30, 2013 5:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok thanks. Seems quite an unorthodox build then, eh? Who needs biasing after all? The most important thing is that it sounds good…
