01012k7
Posted: Sat Aug 31, 2013 4:00 am Post subject:
Hi i am new here Subject description: new member |
Hi I decided to signup here because I am in to electronic synthesiser projects and electronic music I like almost all music ...
I been building electronic projects for about 18 months, I do built a lot of analog synths projects I am not great at electronic but i have a desire to improve also some of the projects I have build I should not have started because they are above my knowledge but they do end up working unless I forgot to wire the output sockets ..
I make a lot of PCB using the transfer paper method also print front panel using the same method also vinyl printing too.
P.S I will post some pictures of projects... |
Joined: Aug 08, 2009 Posts: 1082 Location: Out scouting . . .
Posted: Sat Aug 31, 2013 4:05 am Post subject:
I suspect that you will be able to increase your knowledge here.
Steve |
Joined: Dec 11, 2010 Posts: 966 Location: Toronto, Ontario - Canada
Posted: Sat Aug 31, 2013 9:24 am Post subject:
Hello 01012k7. Welcome to the forums. We talked a while ago about the Korg Monotron. How is that project coming along? I have been meaning to do an online tutorial explaining it better and giving some improved options, but I have been ill and not able to do it. Hopefully I can get around to it soon. I will post it here on the forums when it is completed. _________________ JacobWatters.com |
01012k7
Posted: Sat Aug 31, 2013 12:37 pm Post subject:
Cynosure wrote: | Hello 01012k7. Welcome to the forums. We talked a while ago about the Korg Monotron. How is that project coming along? I have been meaning to do an online tutorial explaining it better and giving some improved options, but I have been ill and not able to do it. Hopefully I can get around to it soon. I will post it here on the forums when it is completed. | not done much with the project to be totally honest sort did not understand that well but I want to get it done before Christmas ...also been very busy with other projects that were easier for me to build
Description: |
pcb boards did not turn out as well as I would have liked but they not been tested ... |
Filesize: |
682.62 KB |
Viewed: |
220 Time(s) |
Description: |
front panel with Korg Monotron will be installed |
Filesize: |
865.29 KB |
Viewed: |
210 Time(s) |
Description: |
Ok made this from 19mm oak flooring also made the switches for the keys |
Filesize: |
603.73 KB |
Viewed: |
211 Time(s) |
Description: |
Oh this my big project which I made over 30+ boards also the keyboard was taken from old midi keyboard which has been change to switches not shure if it will work :) |
Filesize: |
1.29 MB |
Viewed: |
198 Time(s) |
01012k7
Posted: Sun Oct 13, 2013 11:52 am Post subject:
Cynosure wrote: | Hello 01012k7. Welcome to the forums. We talked a while ago about the Korg Monotron. How is that project coming along? I have been meaning to do an online tutorial explaining it better and giving some improved options, but I have been ill and not able to do it. Hopefully I can get around to it soon. I will post it here on the forums when it is completed. | ok started working on this project again first thing I did was buy a metal bender as I decided to make a metal case with oak sides also going to be installing a simple 8 step basic analog sequencer also maybe with the option of having cv and gate inputs ... |
