  Muied Lumens Frequencies
emitter follower to multiple comparators
Page 1 of 1 [5 Posts]
bearblock
PostPosted: Sat Aug 31, 2013 11:12 am    Post subject: emitter follower to multiple comparators Reply with quote  Mark this post and the followings unread
Hi, I've been playing around with the attached circuit and having trouble squashing one bug in particular. Any help much appreciated.
The idea is to compare 2 analogue signals to reference voltages, and also each other, thus generating 3 digital signals. It kind of works but I get unwanted oscillation on the '1 > 2' line when both my input signals go low sometimes. Shouldn't the 1M resistors in the positive feedback loop stop that happening (hysteresis)?
 Filesize:  2.55 MB
 Viewed:  53 Time(s)
gdavis
PostPosted: Sat Aug 31, 2013 1:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
you should have another resistor in series with the emitter and IN+
Actually, you'll need to make another change also if you truly want 1>2 since with hysteresis 1 has to be < 2 by the threshold amount before it will switch. Not sure what the best way to accomplish that is.
frijitz
Audio files: 54
PostPosted: Sat Aug 31, 2013 6:32 pm    Post subject: Re: emitter follower to multiple comparators Reply with quote  Mark this post and the followings unread
Those comparator chips can be touchy to work with. Try running your circuit with a TL074 and see whether it isn't good enough for what you are doing.
Ian
JingleJoe
PostPosted: Sun Sep 01, 2013 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've experimented with LM339 comparators extensively, if I remember rightly, my solution to oscillation was a little cap (like 1n) on the input. Not in series, going from the input to ground like a little low pass filter. However, I just had a voltage divider and compared the other input to that, I had my cap on my voltage divider but with two signals you might want to include a small resistor before the cap to stop it acting as a low impedence path- my thinkign is that it might overload some signal sources.
P.S. forget the hysteresis, it never did anything for me either.
bearblock
PostPosted: Sun Sep 01, 2013 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks guys
Yep this has fixed it Smile i put a 10k in there and it's behaving.
