power Supply help!!
Page 1 of 1 [4 Posts]
djthopa
PostPosted: Mon Sep 02, 2013 4:55 pm    Post subject: power Supply help!! Reply with quote  Mark this post and the followings unread
djthopa
PostPosted: Mon Sep 02, 2013 5:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think i got messed up with the ground and negative in the schematic, i will rewire tomorrow and see if it works. Thanks!
Audio files: 705
PostPosted: Tue Sep 03, 2013 7:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I just took a look at the Tenma Triple Power Supply, but I don't see a negative voltage output. Maybe you can wire two of the three supplies
in series to create a ground connection. but that might be risky, since I have no idea how the supply is wired up internally. (The datasheet on
the farnell site doesn't have nay info about it).
The earth connection is probably wired to earth on the mains input, You could test if you measure a connection between it (unplug the supply first.)
djthopa
PostPosted: Wed Sep 04, 2013 2:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the reply Phobos...im confuse too as it has a negative port.
Shouldnt the negative be the black - Output?
