  Muied Lumens Frequencies
H11F1
Page 2 of 2 [44 Posts]
Goto page: Previous 1, 2
JovianPyx
Audio files: 173
PostPosted: Thu Aug 29, 2013 7:13 am    Post subject: Reply with quote  Mark this post and the followings unread
gdavis: Yes, that does help. It also shows that there is a specific parameter space in which Ic = BIb, that is, not in saturation (and I would assume not in cutoff). So to keep it working as a current source one has to control Ib so that it remains in the "active" state as you described. Very interesting. However, I still have a problem with the variability of beta from unit to unit and I suspect that this is why we don't find such a technique used in professional grade music equipment.
When I wrote about internal impedance changes, I was referring to the current source circuit as a whole. I do see that the current source itself is the transistor so yeah, the impedance changes are external to it.
Time flies like a banana.
corruptio optimi pessima
gdavis
PostPosted: Thu Aug 29, 2013 7:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, you definitely have to control Ib to keep it in the desired operating region, that is what biasing is all about and an important part of any transistor circuit design.
Starting from 0 CV, it will be in cuttoff and the base voltage has to get above the cuttoff voltage before it will enter the active region and start responding. As you continue up you have to get through the "knee" before it starts responding closer to linearly. Taking advantage of the knee is how some exponential converters work. The OP's circuit will probably fail before it ever reaches saturation since there isn't really any resistance to the collector (JovianPyx noticed this as well).
So ya, this is the simplest and probably least effective implementation. There are definitely improvements to be made.
First thing I would suggest is a resistor in series with the collector and LED. Choosing an appropriate value will cause the transistor to reach saturation before a safe current is exceeded.
A resistor between the emitter and ground will help stabilize the effect of varying Hfe a bit.
Carefully choosing the values for all the resistors will allow you to control the overall gain and result in a more well behaved circuit, though still not to the level of an opamp based design, but it's a simple circuit that's easy to implement.
And now he's demonstrating a resistor as a current source! Razz Of course it can work, but puts a heavier demand on the CV driver. But again, depending on the application, just might be good enough.
JovianPyx
Audio files: 173
PostPosted: Fri Aug 30, 2013 3:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, thank you - I had wondered about that "knee" and whether that was what was at the root of expo.
I am confused though, I don't see how a resistor is a current source. You mentioned that the OP used a resistor current source - I don't understand where the current regulation comes into that... is the term "current source" that loose?
Wiki defines current sourse thusly: A current source is an electronic circuit that delivers or absorbs an electric current which is independent of the voltage across it.
The diode in the circuit is nonlinear, so if the resistor is too large, the diode will not switch on and the current will be only the diode leakage current. This means that if one varies the rail voltage to the circuit of LED and resistor R, the current will be far less when the LED diode is off than when it is on.
I do see, however, how a resistor through a linear current measuring device does meet the definition. Just not with the diode in series. OR does the measurement of voltage matter only across the resistor?
gdavis
PostPosted: Fri Aug 30, 2013 5:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, didn't mean to confuse you, I said that mostly tongue-in-cheek.
Wiki does list a resistor in series with a voltage as the "simplest non-ideal current source" in as much as a resistor of a given value with a given voltage drop will produce a specific current as given by ohms law, but I admit that's a bit of a stretch.
JingleJoe
PostPosted: Sun Sep 01, 2013 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
So now that we've discussed a technicality for over a page can we get back to acctually using this as a control element in circuits?
Audio files: 80
PostPosted: Mon Sep 02, 2013 8:15 am    Post subject: Reply with quote  Mark this post and the followings unread
JingleJoe wrote:
So now that we've discussed a technicality for over a page can we get back to actually using this as a control element in circuits?
Have you looked at page 6 in the datasheet? There is an example with a svf and a variable resistor:
http://www.fairchildsemi.com/ds/H1/H11F3M.pdf
Any response yet from Dan on YouTube? I think he had more info about it on his website, but the site is gone.
JacobWatters.com
JovianPyx
Audio files: 173
PostPosted: Mon Sep 02, 2013 8:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Since it uses a MOSFET as the control element, the H11F1 is rather easy to use as a controlling element in a circuit. Essentially, anywhere that a variable resistance is used (not just a rheostat wired pot, but any resistance that varies) this device could be used. Care should be taken to note the MOSFET's resistance range and some modification of the original circuit may be required to accomodate that. It may also take some patience to work with the device's LED current to MOSFET drain-source resistance transfer function.
JingleJoe
PostPosted: Mon Sep 02, 2013 4:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Refresh my memory, who is Dan?
Audio files: 80
PostPosted: Mon Sep 02, 2013 5:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is the only place I have ever seen these optocouplers in use:
http://www.youtube.com/watch?v=Zpf4WLRaU0M
You asked him for a schematic in the comments.
He used to have a website with more info on his projects, but the site is down.
JacobWatters.com
JingleJoe
PostPosted: Tue Sep 03, 2013 2:43 am    Post subject: Reply with quote  Mark this post and the followings unread
oh yeah! what was his old site? maybe I can find a cache or something...
Audio files: 80
PostPosted: Tue Sep 03, 2013 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.whimsofdan.com/
JacobWatters.com
JingleJoe
PostPosted: Tue Sep 03, 2013 2:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm going to send an email to one of the addresses in the whois info for his site;
http://www.whois.com/whois/whimsofdan.com
they are associated with his hosting company but maybe they can give me some leads which could get me in touch with him.
thanks cynosure Smile
Audio files: 80
PostPosted: Tue Sep 03, 2013 6:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
You're welcome. Smile
Have you looked at page 6 of the datasheet that I linked to?
There are examples there for controlling a SVF, opamp gain and a variable resistor. Those should be a good start for whatever you are planning on doing.
JacobWatters.com
JingleJoe
PostPosted: Tue Sep 10, 2013 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah I did have a look at them all when I first found the datasheet but the raise as many questions as they answer.
Experiments gave me most of the answers though Smile
find below links to my vcf which utilizes them. Recorded with a crappy mic and played from a crappy amplifier for extra crappy sound but you get the idea of how raw it can get Smile
http://www.youtube.com/watch?v=3SBtog3WjEk
http://www.youtube.com/watch?v=RQpvwzaNQkA
JingleJoe
PostPosted: Wed Sep 11, 2013 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
P.S. Turns out that dan is really fucking hard to find, all my leads are dead ends! His name may acctually be Dan Whims... I'll search some more.
Audio files: 80
PostPosted: Wed Sep 11, 2013 12:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is how I usually find most of my answers. Either that or Encyclopedia Joviannica Smile
His YouTube name is 'dan a', so I assumed his last name started with an A.
He mentions in the video that he heard about the vactrols on the synth diy newsletter list, so you might want to ask there. You might get a response from him, but even if you don't, there was obviously some discussion there about these things. So there are likely more people there who have experimented with them.
Good luck!
JacobWatters.com
JingleJoe
PostPosted: Thu Sep 12, 2013 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
As you posted above, his website was "whims of dan" (whimsofdan.com) and I've found a Dan Whims with a background in electronics and computers and music, if it's not the guy I'll be damned! Laughing
Audio files: 80
PostPosted: Thu Sep 12, 2013 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
He had his name on his site back when it was still online and it started with an A.
Here is the page to sign up for the synth diy email list:
http://dropmix.xs4all.nl/rick/Emusic/Synth-diy/
As you can see, there are a lot of intelligent and experienced people on that list. Plus, the person says in the YouTube video that he is on the list too.
JacobWatters.com
Audio files: 80
PostPosted: Fri Oct 18, 2013 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I just saw this and thought it was a really cool way to use optocouplers. You could probably do something similar with H11F1.
http://www.youtube.com/watch?v=p2K32HP7yBc
He actually uses the diodes in the circuit as a ladder, and then sends the transferred output to a separate transistor ladder.
JacobWatters.com
