 Forum index » DIY Hardware and Software » Musical Interfaces
PIC based midi controller chip available
Page 1 of 1 [6 Posts]
picsynth
PostPosted: Thu Sep 12, 2013 12:49 am    Post subject: PIC based midi controller chip available Reply with quote  Mark this post and the followings unread
Hi all
Just to let you know that I have released V2 of my PIC midi controller chip. This one supports 5 octaves, a bass pedal, 2 analog controls and 6 organ stops.
http://picsynth.000space.com/midi.html
This chip can also be used to build other custom midi controllers easily...its use in not limited to keyboards!
Kevin
PICSYNTH
amdagan
PostPosted: Sat Sep 14, 2013 5:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey this is looking pretty interesting. DIY Midi suddenly looks a bit less scary than before! I'm more of a fretboard type than keyboard so far, so please be patient with my nooby questions....
1. This is fully polyphonic, right? Just asking because most of your other picsynth stuff seems to be monophonic
2. There is no velocity per key, right? Just a global 'expression' that can be used like velocity for all keys combined - correct?
picsynth
PostPosted: Sat Sep 14, 2013 2:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi
Good questions :
It is 12 note polyphonic
There is no velocity per key just a global "expression" control that alters the velocity sent through for every key
jackdamery
PostPosted: Wed Nov 27, 2013 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Picsynth man, could you use this for MIDI-in to drive a 5v gate out?
burticio
PostPosted: Fri Apr 11, 2014 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is pretty cool!!
I only have some questions. ¿What number part is the PIC Midi Chip? I've googled it and cannot find some specific chip model.
Regards!
PostPosted: Sat Apr 12, 2014 9:18 am    Post subject: Reply with quote  Mark this post and the followings unread
It is a pre-programmed PIC that picsynth programs for this specific purpose. Even if you got the same PIC chip, it would be useless without his code in it.
You could code it yourself, but then using the exact same PIC is not necessary. If you are new to programming chips and want to go the DIY route, then I recommend the Arduino. It is easier to program, has a MIDI library, and there are a lot of tutorials and online support.
