 Forum index » Online Music
Floot Duet #001
Page 1 of 1 [4 Posts]
JovianPyx
Audio files: 190
PostPosted: Sun Sep 15, 2013 4:21 pm    Post subject: Floot Duet #001
Subject description: Floot Duet #001
This started out as a test of my single dsPIC MIDI synthesizer board.
The instrument used is called Floot, or a Floot.
It is a bastardized additive synthesizer in that there are four sound sources, a high quality sine wave, a high quality sine wave an octave above, a distorted sinewave (at the fundamental's pitch) and a noise source. It might be disqualified as an additive synth except that the distorted sine wavetable is still composed of a sum of other sinewaves. It might also be disqualified as an additive synth because of the noise source. The noise is used to provide a breath sound. There is no filter in the audio path in this synthesizer.
It uses pretty much all of the dsPIC except for a small amount (about 1 MIP) for the MIDI controller.
The three sound sources are mixed according to performance directives given through velocity and mod wheel. The synth also has controls for portamento and "air".
There is some pitch bending in the piece, this was done via pitchwheel, the synth has a plus or minus one semitone pitchwheel range. The synth is also capable of portamento.
As I played around with the instrument, I decided to record it. Then I laid down another track using the same instrument. Afterward I added the gverb reverb effect. Here is what came out. Sorry - yes, it is essentially mono.
JovianPyx_Floot_Duet_001.mp3
JovianPyx: Floot Duet #001
 Filename:  JovianPyx_Floot_Duet_001.mp3
 Filesize:  4.49 MB
 Downloaded:  964 Time(s)
Time flies like a banana.
corruptio optimi pessima
Audio files: 574
PostPosted: Mon Sep 16, 2013 7:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
very nice one scott Very Happy
SoundCloud BandCamp AcidTrasH Stickney Synthyards
[Q]
Audio files: 57
PostPosted: Tue Sep 17, 2013 2:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Beautiful Scott Smile
Audio files: 218
G2 patch files: 319
PostPosted: Mon Sep 30, 2013 10:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Lovely :-)
