My Monotron Modification
Page 1 of 1 [14 Posts]
KRS1972
PostPosted: Wed Mar 06, 2013 1:56 pm    Post subject: My Monotron Modification
Subject description: Korg Monotron
Hello !!
Just started to mod my Monotron so i can use it with my modular synth when its finished.
I use a 9 pin sub'd connector that fits just fine in the Monotron.
With a flat cable i connected the sub'd with the points i need.
(Pitch, Gate, Cutoff, VCO out, LFO out, VA, GND, Vbias)
One wire spare.
Some pictures of the result so far.
Now check some schematics and test on breadboard.
Grt,
Chris
Monotron PCB with connection points
 Filesize:  1.23 MB
 Viewed:  630 Time(s)
Monotron case with subd cutout
 Filesize:  1.17 MB
 Viewed:  420 Time(s)
Monotron case completed
 Filesize:  1.18 MB
 Viewed:  421 Time(s)
Monotron with PCB and connected subd
 Filesize:  1.31 MB
 Viewed:  486 Time(s)
Monotron works the same as before with mods
 Filesize:  1.19 MB
 Viewed:  423 Time(s)
KRS1972
PostPosted: Wed Mar 06, 2013 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
UPDATE !!!
Here is the schematic and pcb layout that i want to test.
VCO out and LFO out works fine. (through my mixer, mono)
Spare wire i want to use for audio out. (not on the schema)
Grt,
Chris
 Filesize:  100.98 KB
 Viewed:  27041 Time(s)
 Filesize:  558.42 KB
 Viewed:  1471 Time(s)
KRS1972
PostPosted: Thu Mar 07, 2013 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello !!
I finished the artwork for the aluminium front and is in eurorack format.
Two layouts i designed, one with the sub'd connector and one complete
with the Monotron. (no ribbon controller)
THESE ARE THE RAW VERSIONS !!
When i have all the parts, a final check.
Grt.
Chris
 Filesize:  109.65 KB
 Viewed:  468 Time(s)
 Filesize:  164.9 KB
 Viewed:  668 Time(s)
KRS1972
PostPosted: Sun Mar 10, 2013 8:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Today i finished the front panels.
Art layouts are ok, sub'd connector a little bit higher so it fits better in the eurorack.
My second Monotron arrived for the other front panel.
The ribbon controller i will use later.
Here some pictures.
Grt,
Chris
 Filesize:  1.02 MB
 Viewed:  401 Time(s)
 Filesize:  1.03 MB
 Viewed:  434 Time(s)
 Filesize:  1.25 MB
 Viewed:  467 Time(s)
 Filesize:  1009.66 KB
 Viewed:  485 Time(s)
PostPosted: Sun Mar 10, 2013 8:46 am    Post subject: Reply with quote  Mark this post and the followings unread
The panels look great. Nice work Smile
Do we get to hear a sound demo after they are both complete?
JacobWatters.com
the19thbear
PostPosted: Mon Mar 11, 2013 7:05 am    Post subject: Reply with quote  Mark this post and the followings unread
How did you make that good looking panel?
KRS1972
PostPosted: Mon Mar 11, 2013 1:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
For my eurorack front plates i always use anodized aluminum.
The artwork on the panel is done with "waterslide decal paper", you can get it for laser and inktjet printers.
After that i spray a thin layer of vernish to finish it.
Grt.
Chris
KRS1972
PostPosted: Wed Mar 13, 2013 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here some pictures of the second panel with pcb from the Monotron, pots and jacks.
Grt,
Chris
 Filesize:  1.21 MB
 Viewed:  621 Time(s)
 Filesize:  1.17 MB
 Viewed:  581 Time(s)
bunker
PostPosted: Tue Apr 16, 2013 4:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow! Looks amazing! A couple of questions if I may... What is the function of VA? I checked the schematics and it doesnt seem to be Vbias? I can see from your schematic that you're applying 3v via a voltage reg. Is that voltage normally derived on the main board? What are you bringing it out for? Keep up the good work!!
Bloxelectric
PostPosted: Mon Sep 23, 2013 2:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just found this thread & at the time i am contemplating modding a monotribe or two.
Great work here, really organized looking. I'm an electrical novice but even i can make some sense of your work here. Thanks for all the effort posting here & i would be interested to know how the project is fairing up under the duress of use . Wink Nice one indeed.
Infrablue
PostPosted: Mon Sep 30, 2013 12:57 am    Post subject: Reply with quote  Mark this post and the followings unread
This is GREAT work!
5c4r7
PostPosted: Tue Nov 12, 2013 7:51 pm    Post subject: Faceplate? Reply with quote  Mark this post and the followings unread
Hi There! First off, amazing work! I have to ask, where did you get your faceplate cut and how much did it cost? I sent your design to a company here in Toronto and they wanted $260 to make one for me. I think your mod is awesome and I would really like to make one for myself but, keeping costs down is somewhat imperative for me at the moment. Thanks and keep up the great work!
new voodoo
PostPosted: Thu Nov 14, 2013 6:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am SO doing this. Like THIS WEEKEND..well, probably mid-week next week actually (have 37 other devices in the pipeline but I keep about 4 in circulation being made at same time)
PSYCHED!!
Ive kinda been waiting for a reason to use etchant & copper clads, etc Ive got all the stuff and just havent gtten to it yet. AND i have the monotron for it cause I bught one on a whim and its just been sitting aruond in the living room and to be honest-im tired of hearing "WHeeeUUUmmmmWHEEEEuuuOOOmmmp" whenever a friend decides to pick it up.
Since im in the middle of building a modular and need about 10u more of modules (want to end up filling a 100u case), its perfect!!
fantastic.
Cant say enough good about this.
so cool.
Zodiak
PostPosted: Sun May 10, 2015 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was thinking of doing something similar with my three but couldn't work out how to get the connector on the back of the case, but I never thought of putting it on the side Smile
Stephen
www.Rainsbury.Net
