Making a polysynth out of Waldorf Rockets
Page 1 of 1 [25 Posts]
Audio files: 370
PostPosted: Thu Jul 25, 2013 3:50 am    Post subject: Making a polysynth out of Waldorf Rockets
Subject description: Non-invasive polysynth idea using ChucK
I've had my Waldorf Rocket a while now, and this idea has grown in my head:
Get three to five more to make a polysynth. I can write a ChucK program to distribute MIDI notes. Plus: the Rocket sends and receives midi for the knobs, meaning I can listen for tweaking on one Rocket, and then pass on the MIDI to the others, keeping them synched up. The Rocket is priced at ~ €220. It won't be the cheapest polysynth around, but considering the analog filters (which I love) it won't be the most expensive either.
An optional extra could be to take the audio input from each Rocket into ChucK and mix them there, adding a VCA to each voice so I can control attack (my biggest gripe with the Rocket).
Also I could add extra envelopes in my ChucK program to control whatever parameter on the Rockets I'd like - like a filter envelope separate from the VCA envelope. Might be some zipper artifacts, but worth a try.
Silly idea?
adnauseam
PostPosted: Thu Jul 25, 2013 1:01 pm    Post subject: Re: Making a polysynth out of Waldorf Rockets
Silly idea?
Silly but not impossible! Any reason why one wouldn't just go spend a grand on something more useful.. Juno 106? I know you'd be missing the Supersaws and octave split type stuff that the Rocket has.
I've often thought about this kind of configuration. A virtual software "synth" that's really just a midi processor, with some added structure to help you manipulate hardware with extra envelopes, sequencer type interfaces, midi synced lfos, whatever.
So far I've looked at CTRLR, PureData, and now MAX to do something similar.
Audio files: 370
PostPosted: Fri Jul 26, 2013 3:44 am    Post subject: Re: Making a polysynth out of Waldorf Rockets
I'm sure that the Juno 106 is a very nice synth, if I came across one I'd probably check it out. I've never gotten into buying expensive second hand stuff online...
The reason I had this idea was that I'm so happy with the sound coming out of my Rocket. It can do subtle sounds (as well as thick) that I think would work well with polyphony. It's tweak-friendly, and has that cool midi-implementation.
My other analog poly is the Evolver, which is great but not very good at subtle - I think I would be able to do different things with a Rocket stack.
Also, I'll have four monosynths that I like, that I can use to make big arrangements if I want. Plus they would be easier to fit in my limited space, or stow away when I don't need them.
Also the silliness of it all appeals to me. Smile
PostPosted: Sat Jul 27, 2013 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
It sounds like a cool idea. Although I would do it all in hardware so it isn't tied to a computer. You could do all the MIDI routing with an Arduino or PIC.
Keep us posted if you do decide to try it. I know a lot of people kept bring up the same idea for the Monotron, but I never saw anyone actually try it.
JacobWatters.com
Keysandslots
PostPosted: Sat Aug 17, 2013 6:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Have you looked at the MidiPal from Mutable Instruments? I am doing the same thing you want to do but using a bunch of Shruthis and a MidiPal running the Dispatcher.
Randy
Audio files: 370
PostPosted: Sun Aug 18, 2013 11:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for mentioning MidiPal! Looks like a great device, besides doing the kind of midi routing that I want. Smile Doesn't cost a bundle either.
Keysandslots
PostPosted: Sat Aug 24, 2013 9:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
You're welcome. It is a great little box, along with the other stuff from Mutable.
Randy
Audio files: 370
PostPosted: Sun Sep 22, 2013 5:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok so I went crazy and got myself three more Rockets. Wrote a ChucK program for routing to and between them just now (attached). Just spent some time playing, works like a charm. I'll put up some sound samples and maybe a video sometime soon.
Edit: updated the application, fixing a bug with note offs when more than four keys were pressed down.
multirocket.ck
 Filename:  multirocket.ck
 Filesize:  3.85 KB
 Downloaded:  200 Time(s)
Audio files: 370
PostPosted: Mon Sep 23, 2013 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a video of me playing.
PostPosted: Mon Sep 23, 2013 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Awesome!
And now you have to sell them all to get a new ipad Sad
JacobWatters.com
Audio files: 261
PostPosted: Mon Sep 23, 2013 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's great, a modern 4 voice Smile
Audio files: 370
PostPosted: Mon Sep 23, 2013 11:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks guys. Smile
Yeah the less said about the iPad the better. blackeye For anyone wondering, ask me in chat sometime.
BobTheDog
Audio files: 32
PostPosted: Tue Sep 24, 2013 1:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Brilliant!
PostPosted: Tue Sep 24, 2013 5:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool to see you playing around with your rockets. Does the ChucK script turn the rocket on the right into a control master for the other 3?
Steve
Audio files: 370
PostPosted: Wed Sep 25, 2013 3:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Exactly! The Rocket sends and receives midi for all knobs and almost all switches (a couple of times you will see me throwing the "boost" switch on all units - that one doesn't work with midi). This was the main reason I did this thing, it really works like a knobby polysynth. Smile
And thanks for the cheers guys! Very Happy
Audio files: 370
PostPosted: Thu Sep 26, 2013 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I can report that you can apply the same principle to an Octatrack with eight identical tracks running machines containing identical single cycle sample loops.
A single cycle machine can be seen as a kind of monosynth, and tracks on the octa send and receive midi for parameters on separate channels So you can connect to them just like you would several Rockets, and have one track control parameters for the rest. Neat!
Audio files: 370
PostPosted: Sun Oct 06, 2013 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I implemented the attack trick, where I hook up each Rocket to an input on my sound card, and then process the sound in my ChucK program. I implemented a one second attack for each "voice" which is reset on each note.
Fiddling around with this I made a track, which can be found here. The Rocket sound is run through padaver's nice jellyfish analog delay, and I added some other noises, but I think you get the principle.
Audio files: 370
PostPosted: Sun Oct 06, 2013 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
And here's a recording of me fiddling around with the setup for the octatrack. Before the last third I stopped recording and patched up a different sound with some delay, other than that everything is tweaked live using knobs on track 1 (my program picks up the midi that is sent and broadcasts it to the other tracks).
No other effects added here, it's all octatrack, and me clumsily playing on my keyboard while tweaking. Smile
JeEA
PostPosted: Tue Feb 28, 2017 1:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
Will it be possible with two rockets to make a duophonic
synth without changing the Chuck prog You made?
Will the program run on a Windows or Mac computer?
Jens
Audio files: 370
PostPosted: Tue Feb 28, 2017 9:20 am    Post subject: Reply with quote  Mark this post and the followings unread
JeEA wrote:
Hi
Jens
Well, you need to change this line at the top:
Code:
Rocket rockets[4];
to:
Code:
Rocket rockets[2];
- that will make it duophonic. That number is basically the amount of monosynths you want to hook up to the program.
Note that you will probably need to modify midi channels and device numbers anyway (all in the top lines of the program), since that will usually differ between setups. Some ChucK coding cannot be avoided. :)
Audio files: 370
PostPosted: Tue Feb 28, 2017 9:22 am    Post subject: Reply with quote  Mark this post and the followings unread
And the program should run on both Macs and Windows machines, though I have only tested it on Macs.
JeEA
PostPosted: Tue Feb 28, 2017 11:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great!
How are they connected to the computer?
Will I need two midi out from the computer or is one enough and seriel connection?
Audio files: 370
PostPosted: Wed Mar 01, 2017 12:42 am    Post subject: Reply with quote  Mark this post and the followings unread
You can't route through the Rockets unfortunately, I use either a USB hub or a MIDI Solutions Quadra Through.
JeEA
PostPosted: Wed Mar 01, 2017 3:37 am    Post subject: Reply with quote  Mark this post and the followings unread
So i connect midi kbd via interface In/out
then the two rockets via usb hub and a usb cable
to each rocket right?
Jens
JeEA
PostPosted: Wed Mar 01, 2017 7:23 am    Post subject:   Reply with quote  Mark this post and the followings unread
Just tried to connect the only rocket i have to my Mac.
No reponse. I downloaded Chuck software and Tour program
Just wanted to se if i could send a note. More complicated than i thought.
