Joined: Apr 03, 2004 Posts: 24085 Location: The Netherlands, Enschede
Audio files: 278
Joined: Dec 11, 2010 Posts: 966 Location: Toronto, Ontario - Canada
[Q]
Audio files: 57
Audio files: 278
Posted: Sun Aug 25, 2013 2:40 pm Post subject:
Nice ooh aah's
Thanks for the examples, good stuff.
(added an example to my first post) _________________ Jan
[Q]
Audio files: 57
Posted: Mon Aug 26, 2013 9:13 am Post subject:
This is a demo of Vocaloid 3
It features a hymntune called..
Brother James' Air Air
by
J. L. Macbeth Bain (1840?-1925)
Upper Part sung by Avanna
Lower Part sung by Avanna
Source http://www.mutopiaproject.org/
Description: |
Brother James' Air Air - J L Macbeth Bain - Sung by [Vocaloid Avanna] |
Download |
Filename: |
brother_james_air.wav |
Filesize: |
6.39 MB |
Downloaded: |
914 Time(s) |
Description: |
Brother James' Air Air - J L Macbeth Bain (1840?-1925) - Source http://www.mutopiaproject.org/ |
Download |
Filename: |
brother_james_air-a4.pdf |
Filesize: |
47.54 KB |
Downloaded: |
696 Time(s) |
Audio files: 278
Posted: Thu Sep 26, 2013 4:28 pm Post subject:
My OSX is too old, but on a Mac it can be as easy as:
Code: | set currentUser to long user name of (get system info)
set firstName to first word of currentUser
set lastName to last word of currentUser
set noteValues to {60, 56, 60, 58, 50, 61, 60, 50, 52, 56, 58, 54, 63, 61, 49, 56, 56, 68, 65, 61, 60, 58, 50, 66, 66, 65, 61, 63, 61} -- F
set syllables to {"un", "hap", "p", "hay", "day", "to", "moo", "[[slnc 500]]", "un", "p", "cow", "day", "to", "boo", "[[slnc 500]]", "p", "p", "rain", "day", "dear", firstName, lastName, "[[slnc 500]]", "nap", "p", "sleep", "day", "to", "you"}
repeat with i from 1 to the length of noteValues
set thisValue to item i of noteValues
set thisSyllable to item i of syllables
if length of thisSyllable is less than 3 then
set speakingRate to 220
else
set speakingRate to 100
end if
say thisSyllable pitch thisValue using "Cellos" speaking rate speakingRate modulation 0
end repeat
apparently.
[ source: http://hints.macworld.com/article.php?story=20120204172337402 ]
This is AppleScript, to be entered into the script editor, to be found somewhere in your apps folder. OSX 10.5.8 doesn't do the pitch, speaking rate and modulation parameters for the say command .. so for For 10.5.8 the line
Code: | say thisSyllable pitch thisValue using "Cellos" speaking rate speakingRate modulation 0 |
can be changed to
Code: | say thisValue using "Cellos" |
a bit boring tho ...
What I also used is the say command from the command line, like :
Code: | cat <filename> | say |
which with the Cellos voice is sounding nice for a while -- too bad that a melody can not be set this way, or the speed. (not in 10.5.8 anyway). _________________ Jan
[Q]
Audio files: 57
Audio files: 705
Posted: Fri Sep 27, 2013 4:57 am Post subject:
Warner/Chappell, hmm I always thought it was owned by Disney. Who, just like microsoft, got rich by copying things and then putting copyright on it.
I can't make out if "Good Morning to All" is under copyright too (I could look that up somewhere) if not you are free to play the music as long as you don't
sing the correct words. _________________ "My perf, it's full of holes!"
Audio files: 278
Posted: Fri Sep 27, 2013 9:07 am Post subject:
[Q] wrote: | http://www.nytimes.com/2013/06/14/nyregion/lawsuit-aims-to-strip-happy-birthday-to-you-of-its-copyright.html?_r=0
Oh, right - I changed the composition a bit - is it okay now? _________________ Jan
