<on air> Muied Lumens Frequencies
Need to bounce an idea.
Page 1 of 1 [9 Posts]
Zodiak
PostPosted: Thu Sep 26, 2013 10:11 am    Post subject: Need to bounce an idea. Reply with quote  Mark this post and the followings unread
I am rebuilding my trusty MFOS soundlab on a eurorack panel.
It was already patched out, and I have added several extras over the years like a second PWM, soft sync on both VCOs, and logarithmic CV for the VCA and VCF.
I now want to add inverted outputs for the LFO and AR, trigger level on the AR, and triangle outputs on the VCOs.
My original idea was to hard wire these onto the main panel, but then it struck me that this is going to limit options.
It would be more flexible, but add panel space if I added these as extra eurorack modules.
So do I redesign the front panel AGAIN and make some extra modules or leave them hard wired. ?
Either way is going to mean extra work, but then I like doing that sort of thing, I just don't want to end up finishing it again and then doing it all over in another 5 years Smile
Stephen
www.Rainsbury.Net
PostPosted: Thu Sep 26, 2013 11:06 am    Post subject: Re: Need to bounce an idea. Reply with quote  Mark this post and the followings unread
Shocked
Would maybe having some spare attenuverters and multiples as stand alone modules get what you need without redesigning the panel? They'd be quite useful in general as well....
Zodiak
PostPosted: Thu Sep 26, 2013 12:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, I didn't mention that I am using 4mm stack-able banana plugs so they are their own multiple Smile
On the original the attenuators were on the output of each module, like a VCS-3, and much as I would still love one, my dream synth was probably the ARP 2600 so I have moved my attenuators to the inputs, although every module has a direct input too, so extra attenuators are always a good idea, thanks.
Stephen
www.Rainsbury.Net
PostPosted: Thu Sep 26, 2013 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just to be sure, you saw that I said attenuverters, which also invert signals, right?
Zodiak
PostPosted: Sun Sep 29, 2013 6:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
elmegil wrote:
Just to be sure, you saw that I said attenuators, which also invert signals, right?
Not normally, attenuators allow you to change the amount of a signal from 100% down to 0%. This is used when you want to vary the level of a signal (or control) going into a module.
Invertors turn the signal to -100%.
The unit I am interested in combines both, the signal can be varied from -100%, through 0 and onto +100% of the input, through a single knob.
Stephen
www.Rainsbury.Net
Audio files: 218
G2 patch files: 319
PostPosted: Sun Sep 29, 2013 6:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah ok .. so you do need the attenuverter .. this gets a tad confusing Laughing
Attenuverter is not a speling eror Shocked
edit: I mean
vs
PostPosted: Sun Sep 29, 2013 6:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I said attenuVERTer. You misquoted me here even. I don't know what's up with that.
AttenuVERTers are inverting attenuators. In the center, they're at zero. At full CW, they're at 100%. At full CCW, they're at -100%. Hence, inverted.
An attenuverter is exactly what you want, and is what I said, twice. Not attenuator.
Just so I'm not simply boggling at why I was misquoted, here are some links in this forum to attenuVERTers and/or circuits using them. There are a couple common ways to wire them that I've seen, I don't know whether this set includes more than one though.
http://electro-music.com/forum/viewtopic.php?highlight=attenuverter&t=21916
http://electro-music.com/forum/viewtopic.php?highlight=attenuverter&t=54578
http://electro-music.com/forum/viewtopic.php?highlight=attenuverter&t=27667
Audio files: 218
G2 patch files: 319
PostPosted: Sun Sep 29, 2013 6:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
That was interesting yeah Laughing
piedwagtail
PostPosted: Sun Sep 29, 2013 10:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
queue Pantomine
NO IT DOESN'T
....YES IT DOES
Ohm...
