Stanley Pain
Joined: Sep 02, 2004 Posts: 782 Location: Reading, UK
Audio files: 10
G2 patch files: 35
Posted: Mon Sep 18, 2006 4:26 am Post subject:
how do i build polyphonic sequencers? Subject description: ArGH! |
am i being a total idiot? yes.
can anyone post an example/link to an example of a polyphonic sequencer for the G2?
i can't figure out how to build a sequencer that can trigger 2 or more notes from a single oscillator. and it's twisting my melon!!!!!
i'm sick of:
a) monophonic lines being my only option
b) having to use more oscillators than necessary
obviously the problem goes away if i use an external sequencer... _________________ there's no I in TEAM, so let's all act as individuals instead |
Axiom
G2 patch files: 28
Posted: Mon Sep 18, 2006 5:49 am Post subject:
did you already tried with midi send/receive modules?
Luca _________________
Stanley Pain
Audio files: 10
G2 patch files: 35
Posted: Mon Sep 18, 2006 7:39 am Post subject:
i don't see how that would work... let's say i want to send an A minor triad, 3 notes simultaneously... do i have to use 3 sequencers...? 3 midi send? _________________ there's no I in TEAM, so let's all act as individuals instead |
Joined: Apr 03, 2004 Posts: 22652 Location: The Netherlands, Enschede
Audio files: 228
G2 patch files: 319
Posted: Mon Sep 18, 2006 8:44 am Post subject:
The sequencers are monophonic in nature, they can't have different settings for each voice.
You'll probably need multiple sequencers. Either straight away which means a sequencer for each note of the chord. Or more complicated like one sequencer for the base note and another to select from a set of chords.
I said probably in the above as there is a way to know the voice number in a patch and with some more trickery that could probably be used to select from a set of notes, but more complicated stilland not very intuitive I'd guess.
There is a need for MIDI note send modules only when the sequencer gets too complicated to fit into the patch together with the sound generating stuff. You'd need one MIDI note send per note of the chord I'd think, not really sure though, maybe a bit of trickery would work here, but I guess there would be premature note-offs then. I don't use note sends often enough. _________________ Jan
also .. please don't march .. we are on a bridge right now. |
Stanley Pain
Audio files: 10
G2 patch files: 35
Posted: Mon Sep 18, 2006 2:37 pm Post subject:
i'll figure it out manyana manyana _________________ there's no I in TEAM, so let's all act as individuals instead |
sheridan
Joined: Jun 05, 2005 Posts: 473 Location: London, England
Audio files: 27
Posted: Tue Sep 19, 2006 6:29 am Post subject:
The only way that I could work out envolved using multiple sets of not just sequencers, but oscillators too! I think Jan was right about the Note Send modules being mono too. Alternatively, you can get chords using RandTrig modules with NoteQuant modules, although they'll be... random!
Good luck!
I've just thought... you could connect the Voice No. output of the Status module to the Ctr input of the SeqCtrl module and run the control output of your NoteSeq through the control ports of the SeqCtr... you could then form your chord using the faders on the SeqCtr, although that would be the same for every note... unless you control them with another sequencer for each note using morph controls... but... what a pain! _________________
Sheridan
http://www.nitetimeproductions.co.uk |
Stanley Pain
Audio files: 10
G2 patch files: 35
Posted: Wed Sep 20, 2006 8:13 am Post subject:
sheridan wrote: | The only way that I could work out envolved using multiple sets of not just sequencers, but oscillators too! I think Jan was right about the Note Send modules being mono too. Alternatively, you can get chords using RandTrig modules with NoteQuant modules, although they'll be... random!
Good luck!
I've just thought... you could connect the Voice No. output of the Status module to the Ctr input of the SeqCtrl module and run the control output of your NoteSeq through the control ports of the SeqCtr... you could then form your chord using the faders on the SeqCtr, although that would be the same for every note... unless you control them with another sequencer for each note using morph controls... but... what a pain! |
thanks for the post! there's a lot of food for thought here i'm going to mess with. i quite like the idea of the RandTrig to get random triads...
it's frustrating, because i know it must be possible to have 3 notes triggered simultaneously, if only because you are able to do it via the keyboard. but you can't send 3 different pitches as triggers to the oscillator module... or at least i can't figure out how.
question is having more than one oscillator more economical than having 2 note polyphony...?
then, you'd have to have independent amp envelopes, triggered one after the other, a bit like you'd have when you stacked Novation Bass stations together to create a polyphonic synth...
Rob? Rob? where are you? _________________ there's no I in TEAM, so let's all act as individuals instead |
dasz
Joined: Oct 16, 2004 Posts: 1642 Location: vancouver, canada
Audio files: 29
G2 patch files: 56
Posted: Wed Sep 20, 2006 10:42 am Post subject:
question is having more than one oscillator more economical than having 2 note polyphony...? |
Of course it is better, Once you up the poly to 2 voices, you are committing on some more DSP as well. If your mono patch with 1 osci eats up 54%, then you if you have 2 voices, this eats up an extra DSP Chip for some other osc patch. Imagine now you have your 2 oscs in one patch (the 2nd one eats up 20%) which you copy you add another and you have 3 osc patch (with 3 different midi note rec modules for independant triggering of oscs) at 94% which eats one DSP, vs adding voices (which would eat up 2 DSPs).
But more of a preference, I like to use the latter approach, as each voice can be a completely different instrument, thus creating amazing layering possibilities.
In fact, I just finished such a patch, it is called SectorE_DZ.
/Dasz
Description: |
Filesize: |
21.18 KB |
Viewed: |
29900 Time(s) |
_________________ http://www.dasz.com
Electronic Music Instruments From Vancouver, Canada
(Cycling log - https://www.strava.com/athletes/5681257 ) Last edited by dasz on Wed Sep 20, 2006 1:51 pm; edited 3 times in total |
Joined: Mar 28, 2006 Posts: 1267 Location: Kansas City, Mo USA
Audio files: 31
Posted: Wed Sep 20, 2006 10:49 am Post subject:
This is a great topic. I enjoy little "mind bending" problems.
My analog synth work is hardware-based. If I wanted to do a polyphonic sequence on my Aries modular there are a couple of methods:
Since the sequencer is an 8x2 sequencer, I could do up to eight steps, each step containing two independently settable voltages -- each voltage could be sent to a separate VCO for two-note polyphony.
In addition, my sequencer (and most sequencers) have gate outputs at every step. Say I have three oscillators tracking from the sequencer tuned to form a minor triad. The gate signal could be attenuated to produce a half-step offset (1/12 volt) and applied to the "middle" note. Thus, the chord would change to a major triad on any step where the gate is added.
For that matter -- each gate signal could be split to multiple attenuators and you could get a plethora of discreet voltages for every sequencer step.
In order to get "controlled randomness" you could trigger a sample/hold from the sequencer's clock source. For the sample/hold's input, use an LFO square wave -- use random slow noise (for example) to vary the frequency of the LFO. This way, you would get one of two selected pitches that would vary at random with each clock pulse.
Anyway, this may be off-topic and little help for a G2 user -- perhaps these ideas can be modified and implemented in your G2 patch.
(as I am typing this, it occurs to me that I can set discreet pitches into my sequencer, vary the clock speed at random, and sample/hold the sequencer output.... thus, getting random pitches that are confined to the pitches that I set on the sequencer... can't wait to go home and try it!) |
dasz
Audio files: 29
G2 patch files: 56
Audio files: 31
Posted: Wed Sep 20, 2006 12:37 pm Post subject:
That is a neat patch. Looks like you have Delay in the signal path -- is that enabling you to sound multiple notes simultaneously? |
X-Electric
Joined: Jul 11, 2005 Posts: 181 Location: Warsaw, Poland
Posted: Wed Sep 20, 2006 1:31 pm Post subject:
Here's my straightforward approach to arpeggiators. The patch itself is a simple rendition of cheap plastic keyboards, although I managed to get a harmonic arpeggio line, bass line, drum rhythm and a lead voice still with 3 voices poly on Micro
First 12 notes on a keyboard are meant to choose the base note, and Mod. wheel changes chords from Minor (down) to Major (up). It's pretty easy to use and play. I'm attaching a screenshot and an audio file for those without first generation of Nord Modulars. (Don't mention my crappy play abilities - audio file was made in one shot in a hurry)
Description: |
Filesize: |
278.26 KB |
Viewed: |
584 Time(s) |
Description: |
 Download |
Filename: |
XL_Keyboard.mp3 |
Filesize: |
813.88 KB |
Downloaded: |
761 Time(s) |
dasz
Audio files: 29
G2 patch files: 56
Posted: Wed Sep 20, 2006 1:45 pm Post subject:
kkissinger wrote: | That is a neat patch. Looks like you have Delay in the signal path -- is that enabling you to sound multiple notes simultaneously? |
The delay is for even more layering. I have 2 sound sources, some of them iteracting with each other, based on 3 tone generators.
Perhaps this mp3 is not a good example. It does provide another reason why it is good to put more osc's into one voice vs use 2 voices. For diveristy. I can change the source of each voice (ie interchange the architecture on the fly).
/Dasz Last edited by dasz on Wed Sep 20, 2006 2:27 pm; edited 1 time in total |
Audio files: 228
G2 patch files: 319
Joined: Apr 01, 2004 Posts: 2655 Location: Auckland, New Zealand
G2 patch files: 625
dasz
Audio files: 29
G2 patch files: 56
3phase
G2 patch files: 141
Rob
Joined: Mar 29, 2004 Posts: 580 Location: The Hague/Netherlands/EC
G2 patch files: 109
Posted: Sun Oct 01, 2006 5:33 am Post subject:
Stanley Pain wrote: | Rob? Rob? where are you? |
At home
Triggering multiple notes at once from the FX area to a polyphonic patch by using MIDI modules is straightforward. What needs attention is how you can define chords in a straightforward way, e.g. program each chord separately by using several parallel sequencers, or by defining a system of major/minor/etc separately and then define the key the chord is in by transposing the chord to the wanted key.
Here is some examples where one can trigger several MIDI Out modules from a limited set of notes that can be transposed to a certain key. E.g. in example 2 there are six notes chosen on the MIDI OUT modules. In the intervals of these six notes are both major and minor chords, depending on which of the six notes you trigger. I like this method as it is easy to set up possible chords and then just transpose them to the right key one way or another.
In the patches I use a FlipFlop module where the Q output resets itself. This produces a Gate signal on the Q-bar output that is as long as the time interval between two triggers and goes off for only 1/24000th of a second at the start of a note. I found this a good way to expand the Gate time to layer notes to chords, without destroying the swing as set on the ClkGen module.
Basically programming chords seems all a matter of reducing redundancy. What I often do myself is to see if I can see some system in the chords in a song and then try to minimize redundancy.
I guess there are enough examples in this thread now and in other threads to show that there are several ways to go about and it is just a matter of what sort of approach fits your application best.
/Rob
Description: |
 Download |
Filename: |
Chords4Stanley1.pch2 |
Filesize: |
3.3 KB |
Downloaded: |
1287 Time(s) |
Description: |
 Download |
Filename: |
Chords4Stanley2.pch2 |
Filesize: |
3.73 KB |
Downloaded: |
1317 Time(s) |
Description: |
 Download |
Filename: |
Chords4Stanley3.pch2 |
Filesize: |
4.63 KB |
Downloaded: |
1264 Time(s) |
Stanley Pain
Audio files: 10
G2 patch files: 35
Posted: Fri Dec 08, 2006 10:47 am Post subject:
thanks to everyone for answering this question. there are so many neat [sic] ideas here that i'm looking forward to trying out. _________________ there's no I in TEAM, so let's all act as individuals instead |
cappy2112
Joined: Dec 24, 2004 Posts: 2420 Location: San Jose, California
Posted: Mon Jan 01, 2007 11:58 pm Post subject:
Blue Hell wrote: | A quicxk sketch for a multi sequencer. |
I"m curious- why did you use the 8-input Mux over an 8 input Mixer?
I've connected both, using a switch to toggle between the tow, and there is a noticeable difference. |
Audio files: 228
G2 patch files: 319
Posted: Tue Jan 02, 2007 7:42 am Post subject:
cappy2112 wrote: | I"m curious- why did you use the 8-input Mux over an 8 input Mixer? |
Because the mux selects and the mixer mixes. The idea is to select a different sequencer for each voice. So in voice 1 the topmost sequencer is active, in voice 2 the 2nd, etc. A mixer just mixes the sequences for all voices the same, and so it just won't work for the purpose. _________________ Jan
exeterdown
Joined: Oct 13, 2013 Posts: 47 Location: Melbourne, Australia
Audio files: 228
G2 patch files: 319
exeterdown
Posted: Sat Oct 19, 2013 4:37 am Post subject:
This is really cool.
I'd still love to hear some other takes on the same problem.
I've not really got into the bus systems of the G2 yet though I know that's where it really sets itself apart.
I'm wondering what kind of issues I might come up against using this method and other sequencers in the same patch. Like ones in the FX vs VA areas.
I'll have to do some playing around.
Cheers. |
t4k4sh1
Posted: Wed Oct 30, 2013 4:51 pm Post subject:
Re: Polyphonic Sequencing |
exeterdown wrote: | I've had a hunt around and cant find the answer to this problem.
I've seen examples like using the Status module to achieve individual detuned voices and I know you can get polyphony from the G2.
The problem is when using say the Note Sequencer each new pitch cuts the last one off and each new trigger restarts the Envelope.
To stop each successive note in the sequencer knocking the pitch of the oscillator around after the envelope had been triggered I used a Sample and Hold. But what I'm looking to do is have one sequencer where each new voice is triggered, allowing notes to overlap.
I swear one night while working on this for a while I figured it out and was ecstatic but now can't remember how I did it.
I find using the attached patch if I increase the polyphony all I get is a kind of unison OSC sound with all the voices stacked monophonically.
This feels so obvious but I just cant grok it.
Edit: just saw this:
http://electro-music.com/forum/post-391762.html#391762 |
Use Status and 8Mux like on 3phase's patch above. Basically status module outputs which polyphony it is playing and you can use 8mux to select which sequencer module the polyphony uses. You will need 1 sequencer per polyphony of course, otherwise the notes will be unison.
The patch surface you see will be layered as you rise the polyphony, Status module can tell you which 'layer' it is working.
So if you have a random module based on the poly number, each 'layer' will generate different random value. |
