Sine Subosc
Page 1 of 1 [19 Posts]
isak
PostPosted: Sat Oct 19, 2013 2:20 am    Post subject:  Sine Subosc Reply with quote  Mark this post and the followings unread
Hi Guys.
after listening to the Minibrute Subosc i was very thrilled and wanted to try doing this my self.
so i was looking around and have this idea, hope its a good idea and if not i'll be happy to hear any suggestions about this.
i have a square subosc which works great, my thoughts where to chain it to a lowpass filter and kill all the high freqs, this action will leave me with only the low freqs and if im not mistaken it should look in the scope like a sine wave (not sure about the sound but if it look like a sine it should sound like a sine?).
my next action will be to split the signal with toggle switch, to choose between square sub or going out after the lowpass (sine)
if its a good idea i will need a simple lowpass filter scheme with no need for for FM or reso pot, only with cutoff pot.
what do you think?
Isak E.
analogmonster
PostPosted: Sat Oct 19, 2013 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I wouldn't do it with a (lowpass-) filter, as a filter is frequency dependant. This means you play a high note, you get a sine, you play a low note, and the square is back, or one note disappears, or whatever.
A wave shaper would do a better job. There should be example circuits on the web. Another possibility might be to use a frequency divider cascade à la octavdivider. I use this in my Formant modular.
See also http://www.analog-monster.de/oktavdivider_en.html
If you are interested I send you the schematic (just send me a PM)
Regards
Carsten
http://www.analog-monster.de/index_en.html
isak
PostPosted: Sat Oct 19, 2013 3:42 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for replying and for the input.
is it not only for square waves?
ok, say i use a waveshaper...how will i controll the -1 and -2 octaves?
i know that the main freq is from the VCO it self, meaning the freq will control the waveshaper, or am i wrong and there is a way to do it?
analogmonster
PostPosted: Sat Oct 19, 2013 4:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, but the result is a subharmonic square wave cluster which contains even harmonics, meaning the sound goes into direction of of a deep triangle bass, deeper than a single divider stage.
No, the waveshaper just has a square input and result should be any waveform you like, but of the same frequency. If you have sevaral stages you need more than one waveshaper.
The problem is to find a waveshaper square to sine.
Regards
Carsten
isak
PostPosted: Sat Oct 19, 2013 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
mmm...complicated...
I have the Berfotron saw to tri to sine waveshaper which works great but then again if I want it to be 1 or 2 octave down it should be extra vco.
I will google this sine wave suboctave and see if I find any hint in this matter.
thermionicjunky
PostPosted: Sat Oct 19, 2013 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.bernacomp.com/elec/og2/og3_sine_suboctave.html
Dave Kendall
PostPosted: Sat Oct 19, 2013 1:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
FWIW - on the OG3 schematic posted above, R11 doesn't actually need to be 49.9K - just use two 100K resistors in parallel (= 50K). Similarly, use 300K for R10 instead of 301K- it's a much more common value.
isak
PostPosted: Sat Oct 19, 2013 11:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the input guys.
Out of curiosity I did an expirement yesterday with LP filter on square using vst and vsti, just to give my self an idea of how it should work.
It was success, the only thing is when I play higher octaves/notes then the sound is fading out obviously.
I found a solution for that but didnt try it yet.
Well, connect the CV keyboards to the VCF CV IN and when play higher notes it will open, the cool thing about this is that the max cv keyboards is 5V so it won't open the vcf cutoff all the way and if it will open it to sound a bit like square ill increase the vcf cv in resistor Smile
All i need is a very simple LP filter with CV in, any ideas?
Cheers.
gdavis
PostPosted: Sat Oct 19, 2013 11:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
For this idea to really work you need an LPF with exponential CV which isn't simple to do with much accuracy.
If your source osc is a saw, the circuit posted by thermionicjunky is probably your best bet.
isak
PostPosted: Sat Oct 19, 2013 11:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
not looking for the easy way to do this but in the name of experiment i must try this, only out of curiosity Smile
i'll experiment this today and if i'll succeed i'll upload a Tube clip.
wish me luck Smile
isak
PostPosted: Mon Oct 21, 2013 2:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, just did the test with the ody vco and the mfos svf.
It was almost perfect.
What happens now is I lower the cutoff pot to about 50hrz and the shape in the scope was a perfect sine wave, when going up the scale the sine faded out naturally, so I connected the cv out of my midi2cv to the vcf cv in, it was ok and still got a sine wave shape, but the amplitude was low, when raising the cutoff a bit the amplitude was great and still got the sine wave shape.
5V from the midi2cv is not enough, Ill reduce the 100k of the vcf cv in and see if that will work.
As promised I'll make a vid clip as soon as I fix the key tracking.
Cheers.
gdavis
PostPosted: Mon Oct 21, 2013 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Are you saying that with the keyboard CV the low notes are good but as you go up the keyboard the amplitude still decreases? This would mean you're not tracking 1V/oct accurately enough, there are trimmers to adjust this on the filter. I wouldn't touch the 100k unless you've maxed out the trim.
The V/oct on that filter isn't temp compensated like most VCO's are, so you may never get it perfect. This is why I said this solution wouldn't be simple Wink Might be able to get pretty close though, will be interesting to see how well you can make this work.
isak
PostPosted: Mon Oct 21, 2013 2:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi gdavis and guys Smile
i think you misunderstand me..
i connected the cv out of the midi2cv to a regular cv in of the VCF.
the tracking to the vco works great, the VCF is not 1V/oct, i didnt tune it to be 1V/oct.
its fading out couse the cutoff is closed, this is why, not because the reason you think Wink
now, for the success of my test and i must say im very happy with the results!
it works as i thought it will work!
as BORAT says...."great success" Laughing
now in the vid youll see im playing from C0 to C4, thats more the enough for me as subosc, with more fine tune i can get it to go higher and lower.
enjoy the vid, any comment will be more then welcome.
http://www.youtube.com/watch?v=ORev4PsR7BI&feature=youtu.be
Isak E.
gdavis
PostPosted: Mon Oct 21, 2013 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I understood that you were connecting the KCV to the VCF cutoff CV. Both the svf's circuits I found on the MFOS site have V/OCT cutoff CV inputs. I think you should be able to trim that so that once the cutoff frequency knob is set properly, the VCF cutoff tracks the VCO frequency without changing the 100k.
isak
PostPosted: Mon Oct 21, 2013 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ohh ok, sorry for assuming you didn't.
I know the svf can be 1V/ocv but I didn't trim it for that.
In any way I'm not going to waist the svf to this matter, I'm going to use a simpler vcf I can find, svf was only for the test to see how it will work.
You saw the vid clip? It works well, don't you think? Smile
BTW, eventually I didn't changed the 100k, I replaced it with a 100k pot.
I found here in the forum a simple scheme of vcf, what do you think about it?
http://electro-music.com/forum/phpbb-files/ultrasimplevcf_132.png
And this is the original post..
http://electro-music.com/forum/topic-45231.html&postorder=asc
gdavis
PostPosted: Tue Oct 22, 2013 2:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
no worries Smile
Even if you didn't trim it, the circuit is going to produce an exponential response. Basically, what you did by replacing the 100k resistor with a pot is trim it at the input instead. The problem with that is you affect the input impedance. For a quick test it's not going to cause too much of a problem if you keep the resistance fairly high, but in general it's a bad practice that I would suggest not getting in the habit of doing too much.
Ya, worked better than I thought it would, but again I think it's due in large part to the exponential CV tracking of the cutoff.
To be honest, I don't really know how that circuit works Laughing but I suspect you'll have a more difficult time getting the CV response you need and I'm also a little wary of the 1k summing resistors. But what the heck, it is simple, give it a shot.
isak
PostPosted: Tue Oct 22, 2013 9:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do you think that maybe I can reduce the 100k to say 50k and put a trimmer in series with it the impadance will be ok?
gdavis
PostPosted: Wed Oct 23, 2013 11:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you still talking about the MFOS filter? Why don't you just leave the 100k and use the trimmers that are already there?
If you're talking about the super simple filter then it's less than ideal but if you're hard wiring it to a subosc output it should be fine. You're substituting simplicity for a degree reliability. It's a judgement call based on the particular circuit and what you expect to get out of it but based on what you're trying to do I don't see any problem.
isak
PostPosted: Wed Oct 23, 2013 1:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Talking about the simple VCF.
Thanks for the info and your help Smile
