Building a new bass / melody / lead synth
Page 3 of 3 [67 Posts]
Goto page: Previous 1, 2, 3
Paradigm X
PostPosted: Mon Oct 28, 2013 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Skrog Productions wrote:
FX dismantle & wiring this weekend Smile.
I have taken the pcb out of the stompbox case and it looked quite difficult to take the pots off the manufactured pcb without damaging tracks so, i decided just to snip the pot legs with cutters , leave the pots in place but not connected and run wires from the snipped legs sticking up from the pot thru holes and sleeve them with heatshrink , this allows me to re-assemble the stompbox if i ever need to , unlikely Smile.hurrah ! Smile
hah, great idea, i was wondering how best to rehouse a behriner delay.
what are you doing with the on off switch (foot pedal_? mine defaults to off. Would shorting the pcb coneections work?
looks great, mental wiring. very impressed.
Audio files: 131
PostPosted: Mon Oct 28, 2013 5:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Paradigm X
Smile
On my fx pcb there is a little push switch , i put my continuity meter over the poles to find the switch pins then ran 2 wires from it to a panel mounted push to make momentary switch , when i power up the synth the fx led comes on and i can bypass using the push , i also have a dummy jack in the input of the fx permenantly plugged in , this simplified keeping the multi pole switch jack happy Smile
The orange synth is surprisingly no noiser than my modular system , the fly leads from the pcb's are not much longer than my usual modules and i made sure i cable tied the lfo / adsr cv's & noise wires away from mixer / filter wires.
epicyclus@skrogmusic.plus.com
Audio files: 131
PostPosted: Mon Oct 28, 2013 5:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
oh , i forgot , Delay fx control pots prefer as short a path as possible back to the pcb , if you are wiring to a panel keep the fx pot wires as short as you can.
Smile
Paradigm X
PostPosted: Tue Oct 29, 2013 1:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Great stuff thanks. Ill have a look tonight. Cheers!
Audio files: 131
PostPosted: Tue Nov 05, 2013 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hullo , got a chance to get back to working on the new synth Smile
Fitted two 70mm air vents , that should help the 3 regulator's heatsinks get some fresh air, fixed the sample & hold too (wire mix up Embarassed )
Just need to record and post some sounds from it Very Happy
 Filesize:  181.47 KB
 Viewed:  159 Time(s)
 Filesize:  335.51 KB
 Viewed:  172 Time(s)
Audio files: 131
PostPosted: Tue Nov 05, 2013 1:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Inside the power supply for the modular & new orange synth , had the cover off for temporary hook up to new synth .
Inside the power box i have a 230V to 2x 15v 225VA Torroidal transformer feeding 2x 15A bridge rectifiers with their own 150mm x 50mm x 5mm thick heat sinks and main smoothing caps 4700uF and "line good" green leds for +/- lines .
The Raw DC is 19v on both +/-
Link to original build thread.... http://electro-music.com/forum/post-335363.html
 Filesize:  173.84 KB
 Viewed:  166 Time(s)
Audio files: 131
PostPosted: Tue Nov 05, 2013 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
and with cover on
 Filesize:  150.71 KB
 Viewed:  173 Time(s)
PostPosted: Wed Nov 06, 2013 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I trust you know what you are doing and everything is safe, but is it not dangerous to have those regulator heatsinks attached to wood? Is the wood covered in foil underneath?
Also, I think that the negative regulators I use have voltage on the heatsink. Is that not a risk of creating a spark if those regulators are too close? What happens if some dust or a splinter of wood bridge the gap?
These might be silly questions, but I just want to be cautious before I go repeating what I see you doing, miss something that the pics don't show, and burn my house down. Smile
Audio files: 131
PostPosted: Wed Nov 06, 2013 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Heheheh , Jake , stop it , it's not april 1st yet and im on the floor laughing, here's my reply Razz ,
...Yes, the regulators operate at a nominal 1000degC (higher as i go up the keyboard scale).
For regulator casing voltage insulation properties i used cat skin instead of the usual mica insulators (gives a filter sound that'd make you fall in love).
House fires are Darwins way of ensuring the survival of patient, well grounded & educated diy synth builders.
Smile Very Happy Laughing Surprised Smile Very Happy Laughing Surprised Wink Razz Smile Very Happy Laughing Surprised Razz Cool Wink
Audio files: 216
G2 patch files: 319
PostPosted: Wed Nov 06, 2013 4:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Regulators usually have thermal shutdown somewhere at 150C or so ... to get wood to fire needs higher temperatures - about 600C. And that would have to be for some sustained time, by then the heat problems in electronics usually would have solved themselves.
Sparks is not an issue with the low voltages on the secondary side .. before sparks occur there probably would first be an issue with creep - where current flows over a surface rather than through an arc ... as an indication, for 230 Volt a creep safe distance of about 7.5 mm is used (that would be over a PCB surface) ... so for 50 Volt or so (and it could not get worse than that prolly, even on the unregulated side) ... lets say 2 mm would be safe already.
Spark distances depend on geometry and air conditions a lot ... but let's say about 0.5 cm worst case for 5 kV.
Now when things get wet this would all change a bit .. but even then in a low voltage system I'd expect no problems - with fire that is .. the equipment may get damaged of course ...
PostPosted: Wed Nov 06, 2013 8:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok thanks for clearing up everything. I guess I was just being overly cautious.
Now I need to hunt down some stray cats to get insulation! Laughing
cat
Audio files: 131
PostPosted: Thu Nov 07, 2013 12:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
some sounds Smile ...........
mp3, 1- top part of synth 1 vco sub & square through 24dB vcf / vca into RAT distortion.
mp3, 2- Both vco's 1+2 run through the top vcf / vca , bass sound , no fx , dry sound.
mp3, 3- Mfos sequencer to both vco's 1+2 run through the bottom vcf 12dB / vca, dry sound.
mp3, 4- TechnoFun Smile 2 Mfos sequencers, one to top synth , the other to the bottom synth, turning dials , dry sound.
more sounds with the FX600 at the weekend.
Smile
orange synth square & subs & RAT.mp3
 Filename:  orange synth square & subs & RAT.mp3
 Filesize:  812.82 KB
 Downloaded:  407 Time(s)
Orange synth 2vco's to 24dBvcf with glide.mp3
 Filename:  Orange synth 2vco's to 24dBvcf with glide.mp3
 Filesize:  418.22 KB
 Downloaded:  376 Time(s)
Orange synth 2vco's to 12dB vcf & mfos sequencer.mp3
 Filename:  Orange synth 2vco's to 12dB vcf & mfos sequencer.mp3
 Filesize:  2.15 MB
Orange synth TechnoFun 2sequencers 2 monosynths.mp3
 Filename:  Orange synth TechnoFun 2sequencers 2 monosynths.mp3
 Filesize:  4.11 MB
 Downloaded:  363 Time(s)
Audio files: 131
PostPosted: Tue Nov 12, 2013 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Hullo
Jammed out some more sounds with my Mfos sequencer & Keyboard (korg-X5) into the Poly-DAC 4voice midi to cv converter for some transposed sequences Very Happy .
Sounds 1 - Sequencer & Keyboard vco2 through vcf2 highpass / vca2 to FX600 Flanger.
Sounds 2 -Keyboard vco1 through vcf1 / vca1 to FX600 Chorus.
Sounds 3 -Keyboard vco1 sub through vcf1 / vca1 to FX600 phaser.
Sounds 4 -Random sequence vco1&2 vcf1 / vca1 to FX600 Delay.
and a pic of the new synth nestled into it's tower Very Happy
 Filesize:  315.62 KB
 Viewed:  205 Time(s)
sequencer -vco vcf vca - FX600 flanger.mp3
 Filename:  sequencer -vco vcf vca - FX600 flanger.mp3
 Filesize:  1.86 MB
 Downloaded:  383 Time(s)
keyboard cv & 1 synth thru chorus fx.mp3
 Filename:  keyboard cv & 1 synth thru chorus fx.mp3
 Filesize:  520.84 KB
 Downloaded:  395 Time(s)
ELLL - EFFF - OHHH thru phaser FX.mp3
 Filename:  ELLL - EFFF - OHHH thru phaser FX.mp3
 Filesize:  1.27 MB
 Downloaded:  516 Time(s)
random sequence to 1 then 2 vco's thru Delay FX.mp3
 Filename:  random sequence to 1 then 2 vco's thru Delay FX.mp3
 Filesize:  2.43 MB
 Downloaded:  373 Time(s)
Paradigm X
PostPosted: Tue Sep 09, 2014 6:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, i followed this thread all the way through, and even listened to the demos, but forgot to post afterwards! Embarassed
Excellent sounds and an amazingly flexible synth.
I am currently building a much smaller monosynth type thing. I might ask a question relating to wiring up multiple LFOs to multiple sources etc. if you dont mind.
Amazing job overall tho, and all diy, case, panel, everything.
Nice one.
Cheers, Ben
Audio files: 131
PostPosted: Tue Sep 09, 2014 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Ben , thanks for the comments Smile ,
Yes, distribution of control voltage (from LFO) ..... I usually like to build a simple buffer board if an LFO or ADSR etc has to modulate several destinations.
A purchased MFOS pcb vc-lfo or pcb ADSR usually has a buffer built in at the end of the circuit chain , that is ok for the module to work a couple of cv's , if you need 3 or more destinations simultaneous, it is wise to have a buffer per output , like this , from Ray's archive section....http://www.musicfromouterspace.com/forums.html?MAINTAB=SYNTHDIY&PROJARG=OLDIESBUTGOODIES/VOLTAGEMIXER/voltagedist1.html&VPW=1024&VPH=503 .
 Filename:  cvdistributor.bmp
 Filesize:  712.21 KB
 Downloaded:  141 Time(s)
Paradigm X
PostPosted: Thu Sep 11, 2014 4:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks,
I have been mulling this over, and was thinking theyd need buffering, thanks for the schematics. Some are going via foniks attenuverter chicklets, so im guessing they shoudl be buffered ok?
Funnily enough, i was on a site last night, and found an ideal peice of ply in the skip too! karma
Ill start a new thread maybe, dont want to spoil yours.
cheers, Ben
Audio files: 131
PostPosted: Thu Sep 11, 2014 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Ben Smile
I've not looked at foniks circuit yet , but if the attenuverter is going to feed a lot of cv inputs, buffers will help Smile .
Hehe, site skips are great because they have to separate the waste for recycling, that means lots of nice clean off cuts not spoiled by general rubbish Smile, I usually ask the site agent or general foreman if I can take some off cuts and they are fine with it Smile.
