Bacon
Posted: Thu Oct 31, 2013 6:07 am Post subject:
Building an LFO powered from the gate CV |
I've been searching for an answer to this question on these forums and elswhere but no luck so far:
Is it possible to build a simple and inexpensive LFO that can be powered from a standard +5V gate CV?
The reason I'm asking is that I'm thinking of buying an Arturia Microbrute and I'd like to add an LFO mainly for PWM duties so th internal LFO gets freed up for vibrato. I'll use the Microbrute mainly for soloing in a band setting, so applying vibrato is a must but it would also be nice to be able to have PWM controlled by an LFO at the same time.
I'd like to power the LFO from the Microbrute's gate CV so I won't need yet another PSU to worry about, and I only need the LFO running when I'm actually playing a note so it doesn't have to be powered constantly.
If this is impossible, an LFO that I could power from a wall wart would be OK.
Any suggestions? |
roglok
Posted: Thu Oct 31, 2013 7:27 am Post subject:
i don't think a gate signal will double as a reliable source of power. how about using a rechargeable 9V battery? also, how high do you need the LFO level to be? |
Bacon
Posted: Thu Oct 31, 2013 7:47 am Post subject:
roglok wrote: | i don't think a gate signal will double as a reliable source of power. how about using a rechargeable 9V battery? also, how high do you need the LFO level to be? |
OK, a battery seems like a compromise I could live with.
I really don't know how high the level needs to be. As high as the Microbrute PWM CV input needs to produce a musically useful PWM is the only answer I can give at this time. I haven't bought a Microbrute yet (I don't even think it's in the shops yet) so I can't tell what voltages it expects. If I do get one I guess I could measure the voltage on the Microbrute's LFO CV out.
I'm certainly no novice when it comes to synthesizers – I've been using analog and digital synths since the mid 80s – but interfacing stuff with CVs and gates is a new area for me, since I entered the synth world just when MIDI had become commonplace. |
diablojoy
Joined: Sep 07, 2008 Posts: 805 Location: melbourne australia
Posted: Thu Oct 31, 2013 2:21 pm Post subject:
try pm'ing yves for answers he is very helpful
and as he designed it he will definitely know. he is Yusynth on this forum.
I expect the LFO will be standard output levels of +/-5v.
same for your PWM input , also from the microbrute video's
the CV outputs will drive more than one destination , 3 or 4 reliably i think
although of course that still leaves you with only the one LFO rate, not ideal.
A thomas henry controller LFO would probably be a good candidate for an addition , Fonik may still have boards but you would have to check .
could be built into a small hammond type enclosure with a wall wart supply. _________________ In an infinite universe one might very well
ask where the hell am I
as good an answer as any |
Bacon
Posted: Thu Oct 31, 2013 11:38 pm Post subject:
Thanks for the suggestions! I'll check with Yves if he can nudge me in the right direction. |
