Running a XR-4046 on +/- 12 Volts
Page 1 of 1 [3 Posts]
rumblin_cynth_rampo
PostPosted: Wed Nov 06, 2013 9:02 am    Post subject: Running a XR-4046 on +/- 12 Volts Reply with quote  Mark this post and the followings unread
I really like the sound you can get out of this VCO. So I am going to build a couple. However I want to use a +/- 12V supply.
Has anyone tried the XR-4046 using +/-12V? If you have tried it did you have any problems getting it to run? Did you have to change any component values?
Ian "Lemmy" Kilmister on Hawkwind;
"Like Brahms but violent."
https://soundcloud.com/rumblin_cynth_rampo
inlifeindeath
PostPosted: Sat Nov 09, 2013 6:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
ive built 3 on +-12v and no parts substitutions
rumblin_cynth_rampo
PostPosted: Mon Nov 11, 2013 3:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Many thanks for this. Was hoping to build an example this weekend but as ever other commitments got in the way.
