Weird OUTPUT behavior
Page 1 of 1 [5 Posts]
Rhythm Droid
PostPosted: Thu Nov 07, 2013 8:58 pm    Post subject: Weird OUTPUT behavior
Subject description: where is something loose??
This problem started a few months after I bought my G2 keyboard secondhand.
With cables in both Output 1 and Output 2, anything going to Output 1 is several dB lower than Output 2.
And get this, when I hold the keyboard in my hands and put pressure on the bottom plate, Output 1's strength goes to normal. What do you think? Weak connection somewhere? Anyone had this problem? Must resolve prior to selling my unit (for Engine...my live set must be compact)
varice
Audio files: 29
G2 patch files: 54
PostPosted: Sun Nov 10, 2013 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, that sounds like a possible a weak connection. Could be just about anything though, a loose wire, a cold solder joint, a hairline fracture of a circuit board traceā€¦
But, are you sure that is not cable/plug problem? In my experience, many intermittent connection problems turned out to be due to that instead. Have you noticed if the headphone output is also affected when Output 1 is acting up?
varice
xav
G2 patch files: 7
PostPosted: Fri Nov 15, 2013 4:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Same problem here after a fall.
But something is weird : same level in output 1 or 2 if there is only one jack plugged. The level of output 1 increases if I plug output 2...
Output 3 and 4 level are more hot. And phone level and balance is normal.
I'll double check all the solder joints.
Signifier
PostPosted: Mon Nov 25, 2013 4:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Does it make a difference if you use balanced (TRS) or unbalanced (TS) cables?
xav
G2 patch files: 7
PostPosted: Thu Dec 05, 2013 2:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, there isn't any diference with symetric cables.
