2013 Build Pictures
Page 7 of 8 [178 Posts]
PostPosted: Mon Nov 11, 2013 8:06 am    Post subject: Octomod Ho! Reply with quote  Mark this post and the followings unread
Finally finished this up so I could get some plastic case work to brush up before attacking my x0xb0x case...
 Filesize:  1.51 MB
 Viewed:  139 Time(s)
 Filesize:  1.43 MB
 Viewed:  147 Time(s)
PostPosted: Mon Nov 11, 2013 9:03 am    Post subject: Reply with quote  Mark this post and the followings unread
After an insane amount of work, I finally finished my "Pulse Witch 23" box. It has an infinity mirror in it!
For more details on the circuit and its workings, check out this thread: http://electro-music.com/forum/topic-55283.html .
A demo video can be seen here: http://youtu.be/Tdb6NEecAUU
-- James.
PULSE WITCH 23
 Filesize:  249.29 KB
 Viewed:  140 Time(s)
Audio files: 131
PostPosted: Wed Nov 13, 2013 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi elmegil
What does your octamod box do ?
epicyclus@skrogmusic.plus.com
Audio files: 131
PostPosted: Wed Nov 13, 2013 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi James , nice chamber of led's , looks like you could get your arm in up to the shoulder Smile , nice sounds on the vid.
PostPosted: Wed Nov 13, 2013 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Skrog Productions wrote:
Hi elmegil
The Octomod is a USB -> 8xCV unit.
https://www.tindie.com/products/pucktronix/usb-octomod-1/?pt=directsearch
It's made to be driven by way of OSC/PureData/Max to give 8 general purpose CV outputs.
PostPosted: Wed Nov 13, 2013 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
After the TTSH got postponed, I decided to start this thing. It's been a while - I took the summer off while job and financial insecurity took its toll.
This is either the J3RK Dual Mirror Core VCO or the Stroh Modular Dual Complex VCO. I'm not really sure which. Originally the thread was labeled as per the former, but as things progressed the name morphed to the latter. Either way, it's a really cool collection of vcos and utility modules, with which you can build the complex vco of your choice!
I tried out Front Panel Express's new standoff utility thing, and it worked well, mostly - I had one break off soon after transporting it from my heated studio area to my unheated garage where the soldering happens. No problem though - a little JB Weld and we're back in business.
sduck
I am very impressed with this build. This Dual VCO looks extremely versatile to ! Lots of luck with this one. Cool Too bad about the standoff issue but looks like you had the quick fix at hand. I have seen the new versions of FPE software with added manufacturing options. Will have to check these out Very Happy
Bill
Audio files: 131
PostPosted: Wed Nov 13, 2013 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi elmegil
Ah , that's great , i can imagine some alternative cv's going to filters & wave shapers , great Smile
bearblock
PostPosted: Tue Dec 03, 2013 10:03 am    Post subject: Pressure Pad Array Reply with quote  Mark this post and the followings unread
I've been experimenting with these new Interlink force sensing resistors. Ended up with this box which contains 8 of them, each with independent pressure CV outs.
There's also some CMOS logic for selecting the highest pressure, or the most recently touched sensor, complete with a switch to choose 1x8 or 2x4 (shown) operation. The outputs on the far left and right give you the pressure CV of the selected sensor, as well as stored voltages from the two rows of pots, and triggers/gates controlled by the switches (this last feature was kind of a freebie due to how it all works inside). The pots in the bottom corners control some glide circuits I added because why not.
Runs off a 9V DC adapter. Homemade enclosure out of brass, iroko & spraypaint.
 Filesize:  2.88 MB
 Viewed:  137 Time(s)
Zodiak
PostPosted: Tue Dec 03, 2013 5:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Eurorack MFOS SoundLab (72h) with some extras, like inverted outputs on LFO and AR, triangle outputs for both VCOs and exponential voltage control for VCF and VCA.
The skirts round the switches are there because I drilled the wrong sized holes. They are made from some screw hole covers I had left over from a flat pack bookcase.
The Stig sticker is not staying, and the sellotape on the corners is just there to protect them while I work on it.
The yellow blobs are two transistors and a tempco, glued together and coated with heat sink compound, then encased in heat shrink sleeving. This has given an improvement over having them separately, but in practice the de-tune is still noticeable as my room warms up.
Some of the pots are damaged and I am going to replace the lot. I think it was because I was working on it face down and the shafts have been pushed it, so I have ordered a different type to replace it them.
Stephen
www.Rainsbury.Net
PostPosted: Tue Dec 03, 2013 9:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice work.
I once had tracking issues with a SLMS and contacted Ray about it, and he basically said you're lucky to get much of anything. Turns out I was able to find a subtle error later that made my problem much less, but I never did a temp test, and I wouldn't be surprised if it still drifted some.
sonicwarrior
PostPosted: Wed Dec 04, 2013 12:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Finally finished my Jürgen Haible Tau Phaser with THAT 300 chips (using self made converter sockets):
Posted Image, might have been reduced in size. Click Image to view fullscreen. Posted Image, might have been reduced in size. Click Image to view fullscreen.
And a detail shot of the THAT 300s (can't find the solo pics of the converter sockets on my hard drive):
Uploaded with ImageShack.us
Zodiak
PostPosted: Wed Dec 04, 2013 4:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I am starting to agree and although that's not a major issue it is disappointing. I wanted to use it as a sequencer voice, but it still drifts and doesn't track too well, so I have pretty much given up on that idea and will have to build a couple of VCO modules.
All is not lost though, I had originally planned to build one of Rays sawtooth to triangle circuits as an external module, but as they are so simple I decided to build one onto each VCO and I am glad that I did, because now I can use them a VCLFOs.
I haven't built that bit yet, and I am going to have to modify it to make it DC coupled, and that will required a bit of fiddling, but it shouldn't be that difficult.
And just to be a heretic, I use a PIC to control my sequencer... <GASPS> and that has a spare timer output which is just begging to be used as a sound source and I think that is going to be my solution there. Yes I know its only square out, but put it through 4 stages of dividing and sum them together with the right resistors and it can produce a barely passable triangle and ramp if you squint. Wink
Stephen
www.Rainsbury.Net
dougseidel
PostPosted: Wed Dec 04, 2013 6:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Recent Zeitgeist and double Benjolin (case from old lab ph meter)
 Filesize:  3.42 MB
 Viewed:  127 Time(s)
http://dougseidel/tumblr.com
sduck
PostPosted: Fri Dec 13, 2013 2:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's my version of the Thonk Music Thing Modular Spring Reverb in dualie form. Sounds great!
Thonk Music Thing Dual Spring Reverb front by sduck409, on Flickr
Thonk Music Thing Dual Spring Reverb profile by sduck409, on Flickr
Thonk Music Thing Dual Spring Reverb back by sduck409, on Flickr
Zodiak
PostPosted: Fri Dec 13, 2013 3:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like the front panel sduck, how did you make it?
Stephen
www.Rainsbury.Net
sduck
PostPosted: Fri Dec 13, 2013 5:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's from Front Panel Express in Seattle.
Audio files: 131
PostPosted: Sat Dec 14, 2013 5:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow , nice reverbs Steve , does the black boxes contain the long springs ? Wink
very nice build.
sduck
PostPosted: Sun Dec 15, 2013 9:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
The black boxes are the digital pt2399 based spring emulators - the brick selection on the switches - the springs are mounted in my cabinet, and connect through those minijacks hanging out in the back.
bubzy
Audio files: 63
PostPosted: Sat Dec 21, 2013 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
just finished, started some time ago, maybe 2012 Very Happy
 Filesize:  1.32 MB
 Viewed:  174 Time(s)
_Richard_ Smile
synchroma
PostPosted: Sat Dec 28, 2013 7:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finally, my punk modular synth has taken shape. After a long time of getting the hang of etching boards and making stuff, I actually have a working synth! I think I'd like to get hold of a more iconic case from some broken bit of kit for the box on the right (Thomas Henry VCO1 and VCA from the CA3080 book) but there's more to go in the old Roland case which currently has a Thomas Henry LM-VCO, SSM2044 filter, 2x Yusynth EGs and a couple of sine shapers with overdrive knobs. Smile
 Filesize:  118.68 KB
 Viewed:  141 Time(s)
Audio files: 566
PostPosted: Tue Dec 31, 2013 3:39 pm    Post subject: the Moon Base Xplorer
Subject description: my last finished build for 2013
I got the Moon Base Xplorer finished just before the end of the year Laughing
more info here
(I will upload more pics and demo's next year Cool )
 Filesize:  140.05 KB
 Viewed:  165 Time(s)
 Filesize:  122.1 KB
 Viewed:  136 Time(s)
 Filesize:  94.55 KB
 Viewed:  139 Time(s)
SoundCloud BandCamp AcidTrasH Stickney Synthyards
PostPosted: Tue Dec 31, 2013 6:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Beautiful!
Audio files: 216
G2 patch files: 319
PostPosted: Tue Dec 31, 2013 6:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's one fokking hell of a lovely looking game machinery thing PHOBos Cool
erm .. I mean .. heard some samples of it too I guess lately on you stream?
anyways, looks great!
Audio files: 566
PostPosted: Wed Jan 01, 2014 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks elmegil, jan. Very Happy
I did get some inspiration from how an arcade game looks, and yes you did hear it on my stream.
I will be posting parts of that in the next few days. (just uploaded something here)
DES
PostPosted: Wed Jan 01, 2014 7:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's sharp looking!
www.davesneed.com
