ARDCORE Drum Patterns and Clocks (Video)
alwaysnew
PostPosted: Sun Nov 17, 2013 7:16 pm    Post subject: ARDCORE Drum Patterns and Clocks (Video) Reply with quote  Mark this post and the followings unread
Snazzy FX Ardcore+Expander: Clocks and Drums
Inspired by Grids, RCD, Cloq+CEX, 4MS QCD and more.
See the video for full feature presentation here:
http://www.youtube.com/watch?v=vQLy9Rz1F9M&feature=youtu.be
Patch info:
Blue cable: HD mk1 controlled by Maths
White cable: Noise controlled by ADSRjr
Black cable: Noise through Polivoks filter controlled by ADSRjr
Gray cable: Piston Honda mk1 through AS Chorus/Reverb controlled by Maths
Clock and drum pattern sketches for the Ardcore + Expander from SNAZZY FX
Feed a clock in "Clock in" for external beat. Set A1 to more than 0 for internal beat.
The clock in toggles between D0 and D1 to open and close.
Programs are set with A0. 1, 2, 3... etc from CCW to CW
1. Cycle Program
2. Halves Program
3. Divider Program
4. Drum Program Use A3 to set different drum patterns.
A2 controls probablility of output for triggers. Set A2 full CCW for no randomization and turn it CW for increased "drop out" of trig outs.
There is a 1 second signal as the program is changed.
Get the code here:
https://github.com/Magnus-G/Ardcore/blob/master/Clocks
