  PHOBoS presents: Smokers Delight (not yet confirmed)
Bug: SVF FM Overload
Page 1 of 1 [5 Posts]
PostPosted: Mon Nov 18, 2013 2:54 pm    Post subject: Bug: SVF FM Overload Reply with quote  Mark this post and the followings unread
See the attached for the current patch.
When I turn the Scaler gain or offset way up or way down then it acts like I overloaded the SVF. The output from the SVF stops. It does not output sound even after I return the gain and offset to 0.
The only way to get the sound to return is to remove the patch cable and then replace it.
 Filesize:  122.2 KB
 Viewed:  151 Time(s)
Audio files: 216
G2 patch files: 319
PostPosted: Mon Nov 18, 2013 4:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, will try to reproduce it, thanks!
PostPosted: Mon Nov 18, 2013 10:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
The same thing happened in a delay feedback loop when the amp I was using to control the feedback got too high. Disconnecting the wire and adding it again fixed it, but it seems like once it gets past a certain threshold of feedback, then the pot can't bring it down to a functional level. It just breaks and I hear no sound.
Audio files: 216
G2 patch files: 319
PostPosted: Tue Nov 19, 2013 3:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, yes you can get silly levels that way - signals are clipped on something like +50 dB .. maybe that value should be lower.
Audio files: 216
G2 patch files: 319
PostPosted: Thu Nov 21, 2013 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Seems to be fixed now, both, by adding some clipping on SVF frequency control and feedback input level.
