  Various Artists Live streaming concert in memory of Antimon
Bug: Modules move around weirdly
Page 1 of 1 [6 Posts]
PostPosted: Mon Nov 18, 2013 10:18 pm    Post subject: Bug: Modules move around weirdly Reply with quote  Mark this post and the followings unread
I wasn't any trouble moving and positioning modules until I filled the page vertically. After that, things got weird.
I can't seem to add more space to the bottom of the workspace.
Adding new modules near the bottom actually adds extra space at the top of the workspace. It should add space to the bottom.
If I move all the modules up to fill the extra space at the top, then I loose the space at the bottom again.
Restarting the app and opening my saved file mixes the modules all around. Stuff that used to be at the top is now at the bottom, and there are no longer any gaps between modules.
PostPosted: Mon Nov 18, 2013 10:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh...
and here is the patch.
My screen resolution is only 1366x768 (laptop), so you might need to stack more vertically in order to reproduce the odd behavior.
test1.mpatch
 Filename:  test1.mpatch
 Filesize:  28.93 KB
 Downloaded:  128 Time(s)
Audio files: 213
G2 patch files: 319
PostPosted: Tue Nov 19, 2013 3:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh - could be, scrolling is a PITA thing yes, and indeed didn't run into it ... maybe should disable it all together and add some scroll bars manually instead of using the Delphi scroll box thing.
Audio files: 213
G2 patch files: 319
PostPosted: Tue Nov 19, 2013 6:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ive not been able to reproduce this Confused
Audio files: 213
G2 patch files: 319
PostPosted: Thu Nov 21, 2013 3:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, seeing what you mean now - working on it.
Audio files: 213
G2 patch files: 319
PostPosted: Fri Nov 22, 2013 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Fixed it I think. Also when a new module is dragged in it doesn't expand the client area anymore and modules can not any longer be dragged off screen on left and top sides (and become inaccessible that way) - or naybe that lost bit was introduced with the bug fix - probably so.
Now it still needs a way to follow the mouse - when a wire needs to go to a module currently not visible, or when (a) module(s) get(s) dragged out of visibility on the right or bottom side.
Had assumed that modules would not change their top,left position when in a scroll box .. turns out they do though.
