Midi routing? Help!
Jay-A6
PostPosted: Thu Dec 12, 2013 12:56 pm    Post subject: Midi routing? Help! Reply with quote  Mark this post and the followings unread
Going nuts guys.
I have cubase.
How can I use the MIX mode in the A6 with cubase?
My kurzweil had a mode called local/midi/omni and if you put it on midi then it only worked when you pressed the Monitor button in cubase.
Also when I sequence with cubase it works fine but when I record track two it plays back track one! It then plays back both tracks fine.
Later on I need to fet my cubase audio routed not just dumping 16 midi channles into a "Stereo" out.
Man its a huge mess!
