Sync drum patch to host application
Page 1 of 1 [2 Posts]
Galletas Calientes
PostPosted: Thu May 16, 2013 7:45 pm    Post subject: Sync drum patch to host application Reply with quote  Mark this post and the followings unread
Hi everyone!
This forum is the real deal! Best knowledge base for the G2!
Anyway, hope you guys can help me: I just want my drum patch to sync perfectly with Logic Pro on my mac. I manage to tempo-sync selecting the "master" option in the clkgen module, but I don't manage to beat sync.. I want the loop in the G2 to exactly beat-match the loop on my mac when I start it... I guess I should patch the reset output of the clkgen module to some other module allowing me to achieve that.. but I simply cannot find the proper module..
Any idea?
Thanks a lot
Have a lovely day
exeterdown
PostPosted: Thu Dec 26, 2013 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you have the ClockGenerator on the G2 set to master it should work.
I take it you have a sequence set up on the G2, so when you hit Play in your DAW does the G2 start but is not in sync or does it not start at all?
