<on air> Muied Lumens Frequencies
TR-808 BD in LTSpice
Page 1 of 1 [4 Posts]
mxf
PostPosted: Fri May 04, 2012 5:19 am    Post subject: TR-808 BD in LTSpice
Subject description: won't oscillate
Hello World!
Long time lurker, first time poster here.
I'm quite new to Spice and fail to simulate the bassdrum.
Like Eric Archers
clone, I'm using the substituted transistors and his trigger generator.
Did I make an obvious mistake?
Spice files available here: http://labs.qu.cx/_/bd808.zip
So long, Maik
delta32
PostPosted: Sat May 05, 2012 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
What might be a problem is the 1m resistors being interpreted as 1 MilliOhm in stead of the desired 1 MegaOhm.
Try changing them in '1Meg'.
mxf
PostPosted: Sun May 06, 2012 3:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah! What a glaringly obvious newbie mistake.
Yes, with "1Meg", it does behave more like a 808, i did however
input the resistors as "1M" and thought LTSpice would just do the right thing.
Thank you so much delta32, that cost me some nerves Smile
kreeper_6
PostPosted: Fri Jan 17, 2014 10:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd like to thank you guys, I had the same problem on the exact 808 BD circuit and the solution was the "Meg" labeling.
Smile
