  Muied Lumens Frequencies
CV amplifier circuit troubles
Page 1 of 1 [7 Posts]
alkopop79
PostPosted: Sun Jan 19, 2014 5:35 am    Post subject: CV amplifier circuit troubles
Subject description: op amp non-inverting, cv amp refuses to work
I'm building a sequencer and the CV signal's gain is too low, around 0-0.1V. Any attempt to amplify it with op amp was unsuccessful. I breadboarded a non-inverting amp using a TL072 (tried other op amps, too with no success). It works with audio signal if I add decoupling cap and bias the signal. It doesn't work with the CV signal on the other hand and it only outputs a steady DC voltage of around half 100mV. Any CV amplifiers I've seen are based on the non-inverting op amp amplifier circuit. I've even tried making a buffer and inverting amp but the result is always the same. Please let me know if you have any ideas...
 Filesize:  1.09 KB
 Viewed:  1321 Time(s)
Audio files: 545
PostPosted: Sun Jan 19, 2014 6:39 am    Post subject: Reply with quote  Mark this post and the followings unread
are you using a dual powersupply ?
alkopop79
PostPosted: Sun Jan 19, 2014 7:36 am    Post subject: Reply with quote  Mark this post and the followings unread
No, I use a TLE2425 rail splitter. So far it worked perfectly with other op amp circuits.
tbscope
PostPosted: Sun Jan 19, 2014 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Your current feedback resistor looks low. Maybe the circuit isn't stable.
alkopop79
PostPosted: Sun Jan 19, 2014 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, I'll change the resistor values.
alkopop79
PostPosted: Sun Jan 19, 2014 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
It seems that the op amp works fine as a buffer but won't amplify the signal as a non-iverting amp.
JingleJoe
PostPosted: Sun Jan 19, 2014 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
use an lm324 or lm358, the tl07x series isn't designed to sense so close to GND. also try 30k and 10k resistors, same ratio but less current draw Smile
