Can someone explain something in this schematic for me?
Page 1 of 1 [6 Posts]
new voodoo
PostPosted: Sat Jan 18, 2014 6:14 pm    Post subject: Can someone explain something in this schematic for me? Reply with quote  Mark this post and the followings unread
Im sure its simple but im going to tackle this ASAP and im not sure i completely understand what is happening in the circled section.
If someone can assist?
 Filesize:  116.92 KB
 Viewed:  49 Time(s)
www.newvoodoodesign.com
-my creations, bends & bendable pieces
-vintage parts & tubes, IC's & audio chips
-oddities & weird
newvoodoo.blogspot.com
-bending DIY/projects
-crap
new voodoo
PostPosted: Sat Jan 18, 2014 6:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
heres a link where someone seems t have posted a clearer image of same:
http://m.bareille.free.fr/modular1/vcf_polivoks/polivoks_schem.pdf
-oddities & weird
-crap
PostPosted: Sat Jan 18, 2014 8:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's all power protection. 100uF caps near the power input, and normally the smaller ones would be bypass caps near the power pins of all the ICs. Kind of strange it only lists two. The inductors are likely Ferrite Beads, which are debatable in their usefulness, but somewhat common. They can be replaced by 10 ohm resistors or jumpers. The 10 ohm resistors are basically there to burn out if you have a dead short on one of the rails, and cut the circuit.
tbscope
PostPosted: Sun Jan 19, 2014 12:45 am    Post subject: Reply with quote  Mark this post and the followings unread
The inductors are there to block EMI.
The caps are there to smooth out ripples.
It's basically a filter to make the power rails as clean as possible.
new voodoo
PostPosted: Sun Jan 19, 2014 7:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
thts what I thought-so I might replace it with a lopass hifi/speaker-type filter or nothing or some other thing that functions similarly?
I dont have a lot of inductors,ferrite, inductors, etc-that kinda thing
-oddities & weird
-crap
new voodoo
PostPosted: Sun Jan 19, 2014 7:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
and thank you everyone-Elmegil, tbscope, for your time and assistance. I truly appreciate you taking the time from your own projects, family,work, etc and spending it sharing with and educating me. Truly, thank you
-oddities & weird
-crap
