x0b0x fixing
Page 1 of 1 [12 Posts]
Kosmo Mishka
PostPosted: Fri Jan 24, 2014 12:29 pm    Post subject: x0b0x fixing
Subject description: LEDs
Hi, I bought x0b0x on ebay. It seems all working. But couple things not working:
1. SLIDE, ACC, PREV buttons working, but LEDs never get lid.
2. On Track playing, as I read in manual pressing UP or DOWN should transpose pattern, but that not happening.
I was suggested to update firmware before checking LEDs. But Ladyada forum is down. And I wonder is there any reliable source where I can download latest Sokkos?
3. What is the best manual? I found couple versions, but they not like very good.
Since ladyada forum is down, what is the biggest place where x0b0xers communicate?
PostPosted: Fri Jan 24, 2014 5:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Verify that the LEDs aren't backwards.....
No comments on the rest. I have a couple x0xb0xes in various states, but I haven't spent a lot of time on the forums for them.
Kosmo Mishka
PostPosted: Sat Jan 25, 2014 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Replaced LEDs with 100% working, they still not lighting up.
Also I`ve got spare space for IC15A.
I solved problem with adafruit forum -- somehow my provider blocking it, and I am using proxy to access it.
PostPosted: Sat Jan 25, 2014 5:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
have you verified that they're oriented correctly? I wasn't suggesting that the ones there were bad....
Bizarre that your provider would block that....
Kosmo Mishka
PostPosted: Sun Jan 26, 2014 4:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, they oriented exactly like printed on PCB.
isak
PostPosted: Sun Jan 26, 2014 1:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
What would be the uploaded program?
If it is the sokkos what version?
Here you can find the latest version...
http://forums.adafruit.com/viewtopic.php?f=13&t=3975
If you don't manage to dowload it I'll upload it to you here.
Kosmo Mishka
PostPosted: Sun Jan 26, 2014 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
I uploaded latest sokkos, still no luck with LED. When it turn on all LED blink but ACC and SLIDE not.
isak
PostPosted: Sun Jan 26, 2014 11:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
If your in edit mode (3 o'clock) and play a pattern that haves acc and slide, d the lights light on?
If not the next thing you should check is ic8, is it with socket?
Kosmo Mishka
PostPosted: Mon Jan 27, 2014 5:42 am    Post subject: Reply with quote  Mark this post and the followings unread
No, it never lights on.
How do I check IC8? It is not in socket, solder points seems good. Checked R205 and R204, they are 10K
I am little bit in confusion what pins from IC8 should connect resistors.
According to this schematic http://2.hidemyass.com/ip-3/encoded/Oi8vd2lraS5vcGVubXVzaWNsYWJzLmNvbS93aWtpL3gweGIweD9hY3Rpb249QXR0YWNoRmlsZSZkbz1nZXQmdGFyZ2V0PW1haW5ib2FyZDIucG5n .
IC8 pin 2 > R204
IC8 pin 1 > R205
Ring with multimeter I have:
IC8 pin13, 1,2,8 > R205. R204 Connected same:
IC8 pin13, 1,2,8 > R204
Should not they be connected for only one pin of IC8?
Also pin 13(G) and 1,2,8 on IC8 are connected.
isak
PostPosted: Mon Jan 27, 2014 8:57 am    Post subject: Reply with quote  Mark this post and the followings unread
R205 is Led 39 which is the accent, connected to ic8 pin 1.
R204 is Led 40 which is the slide, connected to ic8 pin 2.
I'll check with mine if the same pins rings when touching the pins you mention.
Kosmo Mishka
PostPosted: Fri Jan 31, 2014 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
That was broken IC8, there was short beetwen pin8 (G) and 1,2. Replaced it, and all works fine.
isak
PostPosted: Fri Jan 31, 2014 7:03 am    Post subject: Reply with quote  Mark this post and the followings unread
happy to hear you got it running.
enjoy your x0x Cool
