Kosmo Mishka
Posted: Fri Jan 24, 2014 12:29 pm Post subject:
x0b0x fixing Subject description: LEDs |
Hi, I bought x0b0x on ebay. It seems all working. But couple things not working:
1. SLIDE, ACC, PREV buttons working, but LEDs never get lid.
2. On Track playing, as I read in manual pressing UP or DOWN should transpose pattern, but that not happening.
I was suggested to update firmware before checking LEDs. But Ladyada forum is down. And I wonder is there any reliable source where I can download latest Sokkos?
3. What is the best manual? I found couple versions, but they not like very good.
Since ladyada forum is down, what is the biggest place where x0b0xers communicate? |
Posted: Fri Jan 24, 2014 5:27 pm Post subject:
Verify that the LEDs aren't backwards.....
No comments on the rest. I have a couple x0xb0xes in various states, but I haven't spent a lot of time on the forums for them. |
Kosmo Mishka
Posted: Sat Jan 25, 2014 3:37 pm Post subject:
Replaced LEDs with 100% working, they still not lighting up.
Also I`ve got spare space for IC15A.
I solved problem with adafruit forum -- somehow my provider blocking it, and I am using proxy to access it. |
Posted: Sat Jan 25, 2014 5:09 pm Post subject:
have you verified that they're oriented correctly? I wasn't suggesting that the ones there were bad....
Bizarre that your provider would block that.... |
Kosmo Mishka
Posted: Sun Jan 26, 2014 4:01 am Post subject:
Yes, they oriented exactly like printed on PCB. |
isak
Kosmo Mishka
Posted: Sun Jan 26, 2014 2:45 pm Post subject:
I uploaded latest sokkos, still no luck with LED. When it turn on all LED blink but ACC and SLIDE not. |
isak
Posted: Sun Jan 26, 2014 11:24 pm Post subject:
If your in edit mode (3 o'clock) and play a pattern that haves acc and slide, d the lights light on?
If not the next thing you should check is ic8, is it with socket? _________________ http://www.myspace.com/mgmtrance |
Kosmo Mishka
Posted: Mon Jan 27, 2014 5:42 am Post subject:
No, it never lights on.
How do I check IC8? It is not in socket, solder points seems good. Checked R205 and R204, they are 10K
I am little bit in confusion what pins from IC8 should connect resistors.
According to this schematic http://2.hidemyass.com/ip-3/encoded/Oi8vd2lraS5vcGVubXVzaWNsYWJzLmNvbS93aWtpL3gweGIweD9hY3Rpb249QXR0YWNoRmlsZSZkbz1nZXQmdGFyZ2V0PW1haW5ib2FyZDIucG5n .
IC8 pin 2 > R204
IC8 pin 1 > R205
Ring with multimeter I have:
IC8 pin13, 1,2,8 > R205. R204 Connected same:
IC8 pin13, 1,2,8 > R204
Should not they be connected for only one pin of IC8?
Also pin 13(G) and 1,2,8 on IC8 are connected. |
isak
Posted: Mon Jan 27, 2014 8:57 am Post subject:
R205 is Led 39 which is the accent, connected to ic8 pin 1.
R204 is Led 40 which is the slide, connected to ic8 pin 2.
I'll check with mine if the same pins rings when touching the pins you mention. _________________ http://www.myspace.com/mgmtrance |
Kosmo Mishka
Posted: Fri Jan 31, 2014 6:53 am Post subject:
That was broken IC8, there was short beetwen pin8 (G) and 1,2. Replaced it, and all works fine. |
isak
