LED-O-SCOPE
Page 1 of 1 [13 Posts]
Audio files: 574
PostPosted: Sun Jan 26, 2014 8:39 am    Post subject: LED-O-SCOPE
Subject description: low resolution oscilloscope
In 2012 I used a mini portable TV to create the Dronoscope and I kept the backcover of the TV for some future use, maybe for a synth or something.
I came across it again while looking for a suitabe housing for a project and when I saw it I got the idea to combine it with something else I had still
laying around: a 10x10 LED matrix that I soldered up > 10 years ago.
Originally I made it to be used for an audioscope circuit using 2 LM3914's, but I never got to that (probably because the LM3914's were too expensive).
So I looked on the web for some inspiration for what I could use it for which led me back to this site, and this thread where Fenris posted the following
schematic:
So I gave that a try it and worked pretty well. Very Happy
But the input needed some boosting and I wanted it to be usefull with AC and DC signals (positive and negative), external time (X) input, a better
offset control and see if I could make it somewhat useful to measure a voltage too.
X / time section:
I started with an oscillator made with a 40106 followed by another inverter as a buffer. The output is connected to the switch contact of the X-in
jack, buffered by a transistor (so it can be used with lower input sgnals) and then turned into a pulsewave which is fed to the CLK input of the 4017.
I used the reset input for the hold switch instead of the clk enable input so when put on hold it will always stop on the first column. The sync input
was added because I had a spare opamp and inverter and it's made with a comparator buffered by the inverter to get a clean CMOS signal. This is
then turned into a short pulse to reset the CD4017.
Y / input signal section:
There's an attenuator on the input for a wide voltage range, followed by a voltage divider which pulls the voltage up. This way AC and negative DC
voltages can be used aswell. I added diodes for protection but they're probably not necessary with the 1M input resistor. The signal is buffered
by opamp u2a and then amplified (+ inverted) by opamp U2d. According to the dataheet the LM324 can swing between 0V and Vdd-1.5, so with a
9V supply that woud be 7.5V, I choose 7V to be sure and biased the opamp at ±3.5V. The signal is then amplified some more by opamp U2c
and this one also has offset control. The offset control is needed for negative DC and AC signals and there's also some offset change when the
input signal is attenuated so that can be corrected aswell. There also a capacitor in the feedback loop to create a lowpass filter which is mostly
there for when it's used as an audioscope. But it also creates nice vertical lines on squarewaves Laughing The output then goes to the input of
the LM3914 that is set to a range of 0..5.1V (zenerdiode).
There's a 9V regulator on the DC input to provide a stable voltage and to make it somewhat useful to measure a voltage I made it so that with an
unattanuated input signal the full range is 1V, and there's a difference of 0.1V between every row. But I'll probably use it as a nice audio visualizer
most of the time Shocked
LED-O-SCOPE schematic
 Filesize:  84.87 KB
 Viewed:  452 Time(s)
TV housing
 Filesize:  62.88 KB
 Viewed:  133 Time(s)
TV housing
 Filesize:  72.24 KB
 Viewed:  129 Time(s)
LED-O-SCOPE front
 Filesize:  67.84 KB
 Viewed:  141 Time(s)
LED-O-SCOPE back (with sync input and trig. level control)
 Filesize:  68.61 KB
 Viewed:  118 Time(s)
SoundCloud BandCamp Stickney Synthyards Captain Collider
Audio files: 574
PostPosted: Sun Jan 26, 2014 8:42 am    Post subject: LED-O-SCOPE
Subject description: wiring pic and animated gifs
wiring pic and some animated gifs Laughing
LED-O-SCOPE - squarewave (animated)
 Filesize:  336.76 KB
 Viewed:  6584 Time(s)
LED-O-SCOPE - sinewave (animated)
 Filesize:  161.55 KB
wiring pic for RingMad
 Filesize:  106.53 KB
 Viewed:  168 Time(s)
PostPosted: Sun Jan 26, 2014 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
You are my hero. Hail the Master
isak
PostPosted: Sun Jan 26, 2014 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi PHOBos
Ones I thought your crazy, now I know your crazy!
Beautyful piece of work!
Audio files: 574
PostPosted: Sun Jan 26, 2014 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks jake,. and it isn't even valentines day yet Razz
isak wrote:
hi PHOBos
Laughing thanks,.. check the build thread in about 5 minutes from now,. just to make sure Wink
LFLab
PostPosted: Mon Jan 27, 2014 4:09 am    Post subject: Reply with quote  Mark this post and the followings unread
effing great! That's really nifty.
PostPosted: Mon Jan 27, 2014 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Mine too!
James
analog_backlash
Audio files: 21
PostPosted: Wed Jan 29, 2014 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for the late reply PHOBoS. It looks great! I remember buying an electronics magazine (in the '80s) which had a very similar idea, but I was put off by the thought of buying 100 LEDs Laughing . They were much more expensive then... I've long since lost the mag, so thanks for the schematic. I suppose that you could extend it by cascading 4017s and LM3914s (but the LED count then rockets upwards).
Gary
Audio files: 574
PostPosted: Thu Jan 30, 2014 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks James, Gary Very Happy
Yes, it could be extended, some extra 4017's would be pretty easy but adding
more LM3914's would need some changes to get the full range. Also with
more 4017's the LED's would be less bright, you could increase the current,
but if the clock is turned off and there is no signal only 1 (or 2 depending on
the offset) LED is on, so you can't make the current too high.
JovianPyx
Audio files: 190
PostPosted: Thu Jan 30, 2014 6:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice work. I like the look from the back too. Fun stuff to be sure.
I have a 256x128 black and white LCD...
Time flies like a banana.
corruptio optimi pessima
roglok
PostPosted: Tue Feb 04, 2014 10:49 am    Post subject: Reply with quote  Mark this post and the followings unread
BEAUTIFUL!
KnobHell
PostPosted: Sat Feb 08, 2014 10:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very cool
The Bad Producer
PostPosted: Sun Feb 09, 2014 6:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow Very Happy I love that!
