rosch
Posted: Wed Aug 03, 2011 12:27 am Post subject:
i asked you about the xpanfader some months ago, as i was lucky enough to get a PS3100 pcb. |
emdot_ambient
Joined: Nov 22, 2009 Posts: 667 Location: Frederick, MD
jojjelito
Joined: Jun 27, 2007 Posts: 50 Location: Stockholm, Sweden
Posted: Thu Aug 04, 2011 3:14 pm Post subject:
Hi Fonik,
I PM:ed you on the 22nd of June about getting a set of one Xpan fader and one PS3100 PCB so I'm definately still on for one set.
Cheers! |
tomcat
Posted: Mon Aug 15, 2011 1:55 pm Post subject:
Matthias, did you get my PM?
(just to be sure this time) |
Posted: Mon Aug 15, 2011 9:53 pm Post subject:
i did. answer soon. _________________
Tech Buddy at Random*Source |
donpachi
Posted: Tue Aug 16, 2011 7:45 am Post subject:
I'd like one Xpan fader and one PS3100 PCB if there will be more. Thanks!!!! |
tomcat
Posted: Tue Aug 16, 2011 8:57 am Post subject:
Thanks Matthias! |
arsonus
Posted: Wed Aug 24, 2011 9:00 am Post subject:
PS3100 VCF + x-pan/fader PCBs arrived today. Thanks.
tokyomatik
Audio files: 6
Posted: Wed Aug 24, 2011 10:26 am Post subject:
ehm....mattias, do you still have some boards available? |
emdot_ambient
raoulblues
Joined: Oct 31, 2007 Posts: 16 Location: paris france
Posted: Wed Aug 24, 2011 12:45 pm Post subject:
PS3100 + x-pan/fader PCB's |
Fonik,
but I would be interested in one of each PS3100 + x-pan/fader PCB's. As a latecomer though, I'd obviously give way to someone who has already expressed an interest.
I'm not in a great rush though, so can probably add it to my PCB order, when that gets sorted.
Regards
raoulblues |
ejr27233
Posted: Sun Nov 06, 2011 2:53 pm Post subject:
Hi
Do you have any 3100 boards left?
Regards
John |
LektroiD
Joined: Aug 23, 2008 Posts: 1019 Location: Scottish Borders
Posted: Sun Nov 20, 2011 11:15 am Post subject:
I'm wondering if there's a way to link a single CV input to all 3 resonators? Since the jack switches are being used by the LFO circuitry, the LFO seems to take priority over the CV ins.
Posted: Mon Nov 21, 2011 7:40 am Post subject:
ejr27233 wrote: | Hi
Regards
John |
no, all sold out again - sorry. _________________
Posted: Mon Nov 21, 2011 7:47 am Post subject:
LektroiD wrote: | I'm wondering if there's a way to link a single CV input to all 3 resonators? Since the jack switches are being used by the LFO circuitry, the LFO seems to take priority over the CV ins.
it is all about the jack socket wiring, isn't it? so there are different options:
omitting the LFO normalization to the CV input sockets, and normalize the three CV in's in a serial or parallel way. you could then patch the LFO to the 2st CV in (you would have to use the inverted LFO switch for an additional inverted LFO out, though).
you could do it with a switch instead of patching.
anyways, just ignore the default normalzing of the sockets provided by the headers on the PCB. _________________
LektroiD
Posted: Wed Nov 23, 2011 7:29 am Post subject:
fonik wrote: | LektroiD wrote: | I'm wondering if there's a way to link a single CV input to all 3 resonators? Since the jack switches are being used by the LFO circuitry, the LFO seems to take priority over the CV ins.
anyways, just ignore the default normalzing of the sockets provided by the headers on the PCB. |
Still scratching my head here (and have tried over and over with various wiring sequences)
As much as I try to get my head around this, I'm finding the text alone hard to understand without a diagram... Is there anyone here who might be kind enough to sketch me a quick diagram to make this easier to understand? |
qfactor
Posted: Fri Jan 31, 2014 2:35 am Post subject:
Sorry for digging up this thread again!
But could someone please upload a stuffed PCB of the Resonator 3100 v3 picture?
I'm wiring up the PCB to the panel and would like to confirm some of its wirings from the PCB.
Thank you!!
Q |
qfactor
Posted: Wed Feb 05, 2014 8:34 am Post subject:
*bump*
Anyone can help me out?
I'm thoroughly confused over how to wire the 3 Depth pots to the single LFO Depth, etc!
Q |
Posted: Mon Feb 10, 2014 2:19 am Post subject:
you have the negativespace panel? _________________
qfactor
Posted: Mon Feb 10, 2014 5:12 am Post subject:
fonik wrote: | you have the negativespace panel? |
Yup! That's the one I have and I want to avoid having to de-solder any incorrect connections. |
Posted: Mon Feb 10, 2014 10:43 am Post subject:
okay, i will have to look up the panel and it'S option, before i can give advice. give me a few hours/days... _________________
qfactor
Posted: Tue Feb 11, 2014 3:32 am Post subject:
fonik wrote: | okay, i will have to look up the panel and it'S option, before i can give advice. give me a few hours/days... |
Alrighty! |
Posted: Tue Feb 11, 2014 3:22 pm Post subject:
so that's what negativspace said:
"[All CV in is] the easiest possible 'kludge' to execute. In this configuration we're eliminating the global LFO Depth control and replacing it with the 3 individual CV input attenuators - which means that you'll have to jumper that header in order to get the LFO signal through it.
Well, don't jumper it with a piece of wire; run it through a switching jack instead. That's your global CV input. Works perfectly, and no hacking the board."
the idea is to omit the single LFO depth pot and route the LFO signal to the switching contact of the All CV In instead.
the All CV In signal is then routed to the switching contacts of the CV inputs. each of these CV inputs is going trough an attenuator pot, then to the PCB. _________________
