3rd run of PCBs for the PS3100 Resonators & the X-panfader
Page 14 of 14 [349 Posts]
Goto page: Previous 1, 2, 3, ..., 12, 13, 14
rosch
PostPosted: Wed Aug 03, 2011 12:27 am    Post subject: Reply with quote  Mark this post and the followings unread
i asked you about the xpanfader some months ago, as i was lucky enough to get a PS3100 pcb.
emdot_ambient
PostPosted: Wed Aug 03, 2011 5:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd like 2 xpanfaders!
Jojjelito
PostPosted: Thu Aug 04, 2011 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Fonik,
I PM:ed you on the 22nd of June about getting a set of one Xpan fader and one PS3100 PCB so I'm definately still on for one set.
Cheers!
tomcat
PostPosted: Mon Aug 15, 2011 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Matthias, did you get my PM?
(just to be sure this time)
PostPosted: Mon Aug 15, 2011 9:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
i did. answer soon.
Tech Budday at Random*Source
donpachi
PostPosted: Tue Aug 16, 2011 7:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd like one Xpan fader and one PS3100 PCB if there will be more. Thanks!!!!
tomcat
PostPosted: Tue Aug 16, 2011 8:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Matthias! Very Happy
arsonus
PostPosted: Wed Aug 24, 2011 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
PS3100 VCF + x-pan/fader PCBs arrived today. Thanks.
tokyomatik
Audio files: 6
PostPosted: Wed Aug 24, 2011 10:26 am    Post subject: Reply with quote  Mark this post and the followings unread
ehm....mattias, do you still have some boards available?
emdot_ambient
PostPosted: Wed Aug 24, 2011 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
x-pan/fader PCBs arrived yesterday thumb up
Good things come to he who waits: SUCCESS!
raoulblues
PostPosted: Wed Aug 24, 2011 12:45 pm    Post subject: PS3100 + x-pan/fader PCB's Reply with quote  Mark this post and the followings unread
Fonik,
but I would be interested in one of each PS3100 + x-pan/fader PCB's. As a latecomer though, I'd obviously give way to someone who has already expressed an interest.
I'm not in a great rush though, so can probably add it to my PCB order, when that gets sorted.
Regards
raoulblues
ejr27233
PostPosted: Sun Nov 06, 2011 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi
Do you have any 3100 boards left?
Regards
John
LektroiD
PostPosted: Sun Nov 20, 2011 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm wondering if there's a way to link a single CV input to all 3 resonators? Since the jack switches are being used by the LFO circuitry, the LFO seems to take priority over the CV ins.
Question
PostPosted: Mon Nov 21, 2011 7:40 am    Post subject: Reply with quote  Mark this post and the followings unread
ejr27233 wrote:
Hi
Regards
John
no, all sold out again - sorry.
PostPosted: Mon Nov 21, 2011 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Question
it is all about the jack socket wiring, isn't it? so there are different options:
omitting the LFO normalization to the CV input sockets, and normalize the three CV in's in a serial or parallel way. you could then patch the LFO to the 2st CV in (you would have to use the inverted LFO switch for an additional inverted LFO out, though).
you could do it with a switch instead of patching.
anyways, just ignore the default normalzing of the sockets provided by the headers on the PCB.
LektroiD
PostPosted: Wed Nov 23, 2011 7:29 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
Question
Still scratching my head here (and have tried over and over with various wiring sequences)
As much as I try to get my head around this, I'm finding the text alone hard to understand without a diagram... Is there anyone here who might be kind enough to sketch me a quick diagram to make this easier to understand?
PostPosted: Wed Nov 23, 2011 8:16 am    Post subject: Reply with quote  Mark this post and the followings unread
okay, here is a srawly sketch, made with a blunt pen.
the idea was to normalize the input sockets off-board, thus leaving pin2 of the connector headers open. the sketch shows a cascading normalization.
you then could manually patch in the LFO
or
(optional) normalize pin2 of SW1 to CV in1, using a ON/OFF/ON switch. you then could switch in the LFO/-LFO to CV1...
 Filesize:  204.37 KB
 Viewed:  363 Time(s)
qfactor
PostPosted: Fri Jan 31, 2014 2:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for digging up this thread again!
But could someone please upload a stuffed PCB of the Resonator 3100 v3 picture?
I'm wiring up the PCB to the panel and would like to confirm some of its wirings from the PCB.
Thank you!! Very Happy
Q
qfactor
PostPosted: Wed Feb 05, 2014 8:34 am    Post subject: Reply with quote  Mark this post and the followings unread
*bump*
Anyone can help me out?
I'm thoroughly confused over how to wire the 3 Depth pots to the single LFO Depth, etc! Shocked
Q
PostPosted: Mon Feb 10, 2014 2:19 am    Post subject: Reply with quote  Mark this post and the followings unread
you have the negativespace panel?
qfactor
PostPosted: Mon Feb 10, 2014 5:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Yup! That's the one I have and I want to avoid having to de-solder any incorrect connections. Shocked
PostPosted: Mon Feb 10, 2014 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
okay, i will have to look up the panel and it'S option, before i can give advice. give me a few hours/days...
qfactor
PostPosted: Tue Feb 11, 2014 3:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Alrighty! salut
PostPosted: Tue Feb 11, 2014 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
so that's what negativspace said:
"[All CV in is] the easiest possible 'kludge' to execute. In this configuration we're eliminating the global LFO Depth control and replacing it with the 3 individual CV input attenuators - which means that you'll have to jumper that header in order to get the LFO signal through it.
Well, don't jumper it with a piece of wire; run it through a switching jack instead. That's your global CV input. Works perfectly, and no hacking the board."
the idea is to omit the single LFO depth pot and route the LFO signal to the switching contact of the All CV In instead.
the All CV In signal is then routed to the switching contacts of the CV inputs. each of these CV inputs is going trough an attenuator pot, then to the PCB.
