mixer voltage output
Page 1 of 1 [3 Posts]
capicoso
PostPosted: Wed Jan 15, 2014 6:25 pm    Post subject: mixer voltage output Reply with quote  Mark this post and the followings unread
Hi. I finished the 1U mixer, and my idea of building it was to get a line level on the output, so i can connect them to other synths, or processors, etc. Can I just make the voltage lower by changing Rin in the output opa? Will the signal be degraded or something? Thanks
Smile
yusynth
PostPosted: Fri Jan 17, 2014 6:27 am    Post subject: Reply with quote  Mark this post and the followings unread
No, I would rather suggest that you play withe value of R7 (decrease it you want reduce the output level).
Otherwise a simpler solution is to insert a resistor at the connector J1(h an i) instead of a strap.
Yves
capicoso
PostPosted: Tue Feb 11, 2014 5:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Yves. I think i'll just leave it as it's and build a cv delay/echo
