Would it be possible to make a GUI in M4L?
Page 1 of 1 [7 Posts]
wheely
PostPosted: Mon Feb 10, 2014 12:31 pm    Post subject: Would it be possible to make a GUI in M4L? Reply with quote  Mark this post and the followings unread
Hi all.
I was wondering, could it be possible to make the same modules in max for live to control the G2? So that there would be no need for the G2 Editor anymore.
Audio files: 216
G2 patch files: 319
PostPosted: Mon Feb 10, 2014 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not sure if you saw http://electro-music.com/forum/topic-48872.html (start at the end maybe instead of the beginning of that thread) ... different solution, same idea.
Ah .. M4L is max I see just now.
I dont know if that one could be made to do USB?
brunov
PostPosted: Mon Feb 10, 2014 1:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
On the G2 all the patching functions, adding modules cables and so on, are only accesible through usb.
I'm not a m4L expert, but don't think you can build a usb interface in that.
I'v build a Vst one time that controls the open source editor through tcpip, so in principle, it could be controlled by osc commands also. But you would need to have an editor running.
My old OS NMG2 editor: http://sourceforge.net/projects/nmg2editor/?source=directory
My new G2 editor FMX: http://www.bverhue.nl/g2dev/?page_id=17
Source code: https://github.com/BVerhue/nord_g2_editor
wheely
PostPosted: Tue Feb 11, 2014 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok i see. but if say the editor program was on, maybe it would be possible to make max msp modules have them saved in ableton?
theres a way to link modules together in ableton now..
http://www.synthtopia.com/content/2014/02/10/dope-matrix-puts-a-modular-synthesizer-into-ableton-live/
would be super cool to make your environment in ableton, in your daw.
adnauseam
PostPosted: Tue Feb 11, 2014 6:36 pm    Post subject: I saw this.. Reply with quote  Mark this post and the followings unread
But it left a little bit to be desired.
You've gotta have one of the supported control interfaces... for one Smile
wheely
PostPosted: Tue Feb 11, 2014 7:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
na, if its possible now to use 'patch' cables to connect ableton module and max patches in this manner then it could be possible to make a G2 environment, if you knew how.. without one of those 3 interfaces
adnauseam
PostPosted: Tue Feb 11, 2014 7:32 pm    Post subject: Why I say.. Reply with quote  Mark this post and the followings unread
that it "leaves something to be desired" is because the visual patching is abdicated to some sort of matrix style connections. It's likely that everything is connected to everything and pressing those buttons opens/closes virtual switches between them. So in a sense it's semimodular.
Max/M4L itself is actually a great place to do some modular experiments. In fact I believe there are or have been projects designed to mimic the Nord Modular "way" of synthesis.
One I've come across recently (although I can't say if it's "Nord-like") is called BEAP.
