Global Outputs?
Page 1 of 1 [2 Posts]
rufuss sewell
PostPosted: Sat Feb 08, 2014 1:07 am    Post subject: Global Outputs? Reply with quote  Mark this post and the followings unread
Usually when I'm programming I'll use headphones on the main out.
While recording I'll use the AUX outputs.
Is there any way to switch outputs globally rather than by program? It's quite tedious when surfing through 100 presets to always have to re-program the outputs for each patch.
Or perhaps a way to mirror the outputs?
I also notice that if I program a pan mod I have to choose which output gets the mod. I'd really like them always to be the same.
sunny pedaal
Audio files: 12
PostPosted: Fri Feb 14, 2014 3:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
i think it's limitations indeed.
i normally use 2 pair inputs on my mixer , and switch there by mute knobs.
