frijitz
Audio files: 54
Posted: Sun Nov 18, 2012 11:25 am Post subject:
Benjamin AM wrote: | I finally got around to getting this circuit on a breadboard. I eventually ended up using a softpot instead of using ESD ribbon. I noticed that the CV output ranged from 0V to 4V. To change this I adjusted the value of the 120k resistor attached to A4's negative input. Doubling the value(changing it to 240k) dropped the output to a range of -2V to 2V as the schematics indicates. I was curious if this sounds right. |
Sounds OK. You can use whatever output range and offset suits your needs, of course. +/-2V is convenient with my system.
Quote: | Also, I was curious if other ribbon controllers designs that use the softpot exhibit the phenomenon that has been deemed as the "squish factor", that is, pitch bending on finger pull off. |
On the Appendage controller, an earlier voltage is put out. Scott said this eliminated the squish factor. I'm working on a new design that uses two smoothing times. This also appears to work well.
Quote: | Anyhow, thank you so much for contributing this design, I look forward to the spending many hours playing this thing. |
You are welcome! It's good to see someone working with it.
Quote: | Edit: I forgot to mention that I used CA3080s in place of the LM13700. Seems to be no problem. |
Yeah, they're the same basic circuit.
Ian |
Benjamin AM
Posted: Sun Nov 18, 2012 7:07 pm Post subject:
frijitz wrote: | I'm working on a new design that uses two smoothing times. This also appears to work well. |
Sounds interesting! I can't wait to see it. Out of curiosity, does this mean that when the player removes his finger from ribbon the the CV lag time(A2-A3) will increase?
-Benjamin |
OE
Joined: Feb 26, 2014 Posts: 3 Location: United States
Posted: Thu Feb 27, 2014 12:05 pm Post subject:
Hello! First post on this fine forum, but I was seeking a simple ribbon controller. The appendage is just too much for me at the moment - although it is an incredible design. I wanted to see if you had come up with the updated schematic you had referenced. I'd like to make a PCB for it and have it shared on the OSH park PCB fab site for free if any one wants to get a PCB for themselves (if that is OK with you, frijitz!)
Thanks for the contribution, I look forward to seeing the updated project. |
OE
Posted: Sat Mar 01, 2014 5:51 pm Post subject:
Here is a PCB and the corresponding schematic. It hasn't been tested yet, but if anyone wants to give it a try, they are more than welcome. I'll be getting it fab'd when I get a chance/money. I assume the diodes that are zener's can be a 1N400x type? Dimensions are ~3" x 1.4". The TL072 is a OPA134, I just didn't have the right component in the library. It will be edited when the board is finalized.
EDIT: removed. Last edited by OE on Sun Mar 02, 2014 12:00 am; edited 1 time in total |
frijitz
Audio files: 54
Posted: Sat Mar 01, 2014 7:20 pm Post subject:
That is an older schematic and is no longer recommended. Plus, you did not get my permission to do this.
Ian |
OE
Posted: Sun Mar 02, 2014 12:06 am Post subject:
I apologize! It has been removed. I assumed schematics posted for use were also allowed to have PCBs made. I am sorry. |
softfin
Joined: Oct 11, 2006 Posts: 271 Location: Far in the north
Posted: Sat Apr 04, 2015 3:08 am Post subject:
I have a few spare softpots, so I though I could built this one on stripboard. However, all the softpots I have are 10k. Is it possible to build this ribbon controller with a 10k softpot? Advice would be much appreciated. |
